motorised systemsInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 18-08-2007 Location: peterborough
My System: sky+ Bt Total Broadband | hi all was looking for some help i am taking up the hobby of satellite tv and was wondering what would be the best system to get seen a lot about the technomate 1500 is it any good also where can i buy the whole kit from as i'm not sure what to add or not, will a 90cm dish pick up all satellites east to west many thanks | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hello Pasha99 and welcome to the forum I've moved your request to a more appropriate section. Have a look through the other threads/posts to get a feel for things. There's lots to get your teeth into. The Technomate 1500CI + is a very good and reasonably priced receiver. | ||
| The Following User Says Thank You to jimbo For This Useful Post: | pasha99 (18-08-2007) |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Hi, Both the technomate and a 90cm dish are a very good start. The technomate 1000 series are very easy to use. Have a look at the site sponsors sites to see if you can get it all from one place. http://www.satellites.co.uk/index.php?page=sponsors Have a look at Rolfs tutorial to see what mounting hardware you will need. http://www.satellites.co.uk/satellit...or-others.html there is another by longstockings. Basically you will need: Receiver Dish (pole mount type) Motor (H-H) Good quality Satellite Cable F-Connectors x4 Pole + T K brackets (better) or wall bracket (not as good) Satellite finder meter (optional, but makes things easier) self amalgamating tape or boots Cable clips (8mm I think) | ||
| The Following User Says Thank You to Robbo For This Useful Post: | pasha99 (18-08-2007) |
My System: sky+ Bt Total Broadband | i have just had a look at a technomate 1500ci+super + a triax td88 90cm motorised dish and they will fully load it for motorised use do i need a v-box? what do they do sorry i'm a bit thick but i'm learning | ||
| | #5 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | It depends on what motor you get. For a Diseqc motor a V-box is not required. The V-box is needed for the more powerful and faster 36V motors | ||
| motorised, systems |
