Astra 1 channels 'no signal' | |
| Guest
Posts: n/a
Hello, For some years I've been viewing analogue fta channels from Hotbird and Astra 1. The picture quality from my fixed 80cm dish (dual LNB) has been exceptionally good. I've now replaced the analogue Pace receiver with a digital Humax F1 VACI. Again, the quality of picture is extremely good from both 13 degrees and 19.2. Signal strength is about 50-60% and quality about 70-80% . However, I am unable to receive some of the listed Astra channels. Examples are: Travel and Sky News, both fta on Astra 1G. I have tried 'auto search', 'manual search' and 'advanced search' (using video and audio PID ). Each attempt returns ' no signal'. As a digital novice, I'm unsure of what to check first. Regards Andy | ||
| Honorary Admin Join Date: 01-01-1999 Location: Cloud Cuckoo Land
well, it's a long-shot but here's an idea: Both of the channels you mention are vertically polarised. I'm wondering if you do not have a universal LNB. Perhaps you have an older LNB with separate vertical and hortizontal outputs, and either a switch box feeding a single line from your old analogue receiver or esle both LNB outputs going directly to the receiver. In any event, when you use your digital receiver to switch between channels of different polarisation, it automatically sends a special signal up the coax to your LNB's polarisor, to cause it to select the right state. But only universal types recognise that signal. And if you have replaced your old LNB with a new universal type, did you also get rid of the switch box? You should. See if you can receive any of the following FTA vertical signals: - Canal Canarias (12441/v/27500 fec 3/4) - Motors-TV (12610/v/22000 fec 5/6) - CNN-Int (12168/v/27500 fec 3/4) or indeed ANY Vertical signals... 2old | ||
| | #3 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. |
[font size="1" color="#FF0000"]LAST EDITED ON 09-Jan-01 AT 08:58 PM (GMT)[/font][p]Try typing in the frequency direct Vertical polarisation 12552.00 Freq 22,000 Symbol Rate 5/6 Forward error correction/viterbi Rate Make sure the 22Khz tone switch is on or at least on auto. Hope this is of help Rolf Sorry I've just noticed that you say you have been using a dual LNB, if it is a dual then as 2old say's, it has a vertical and hoizontal output, if it's a twin then the 2 outputs are bi-polar and either one can be used. You say that you are looking at 2 satellites, do I presume that you are using a double mount bracket or by dual , do yuo mean a monobloc 2 sat lnb.
__________________ | |||
| Guest
Posts: n/a
[font size="1" color="#FF0000"]LAST EDITED ON 09-Jan-01 AT 09:45 PM (GMT)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 09-Jan-01 AT 09:33*PM (GMT)[/font] 2old, Thanks for pointing me in the right direction. Yes, your quite right, it turns out that its the vertically polarised channels that are missing. However, there's no switch box. The Pace had 2 LNB inputs and they were fed direct. (I've Just seen Rolf's reply and I see that I have misled you by using the term dual instead of 2 LNBs. My apologies) I was led to believe that I had 2 universal LNB's by guy who installed the original Pace system. In fact, he had to change the one (13 degrees) to a universal because I couldn't switch to the high band when searching channels. From then on I was able to switch high/low on both LNB's so I assumed they were both universal. Anyhow, I got the ladders out today to have a look. Hotbird is clearly marked as a Grundig Universal 0.8dB LNB. As for the Astra, well, it's hard to make out, but I could see L.O. 9.75 Ghz Euro120 1.0dB. Can I assume that it's a straight forward operation to change an LNB. If so, I'm off to the local Sat shop. Many thanks Andy | ||
| | #5 | |||
Hi Andy, I don't know if 2Old is still monitoring, but if he isn't then yes it's a piece of cake to switch from an enhanced LNB ( would have been used to enable the new channels like channel 5 ) to a universal. You should get a slight improvement on the newer LNB as most of them are 0.7 db or less as a noise figure. Make sure that the new lnb is skewed properly, I'm not sure of the exact figure for Astra 19.2, but I think that it's about 4 degrees, so if you are looking at the dish from behind the LNB it will be a slight rotation clockwise off the vertical. Good luck Rolf
| | #7 | ||
| Guest
Posts: n/a
>well, it's a long-shot but here's >an idea: > >Both of the channels you mention >are vertically polarised. >I'm wondering if you do not >have a universal LNB. Perhaps >you have an older LNB >with separate vertical and hortizontal >outputs, and either a switch >box feeding a single line >from your old analogue receiver >or esle both LNB outputs >going directly to the receiver. > > >In any event, when you use >your digital receiver to switch >between channels of different polarisation, >it automatically sends a special >signal up the coax to >your LNB's polarisor, to cause >it to select the right >state. >But only universal types recognise that >signal. > >And if you have replaced your >old LNB with a new >universal type, did you also >get rid of the switch >box? You should. > >See if you can receive any >of the following FTA vertical >signals: >- Canal Canarias (12441/v/27500 fec 3/4) > >- Motors-TV (12610/v/22000 fec 5/6) >- CNN-Int (12168/v/27500 fec 3/4) >or indeed ANY Vertical signals... > >2old | ||
Similar Threads | ||||
| ASTRA 2D BBC & ITV RECEPTION | Expat | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 574 | 4 Weeks Ago 09:06 PM |
| Indian DTH: Dish/TataSky/DDDirect+ (All Info) V2 | Analoguesat | Dedicated DTH (India and Region) | 706 | 05-09-2006 12:25 PM |
| Mezzo in clear from Astra | net1 | Daily Satellite and Broadcast industry News | 0 | 08-02-2004 08:06 PM |
| WDR package from Astra | net1 | Transponders & channels | 1 | 18-01-2004 10:09 PM |
| sky sat signal weak | sky do i bother? | Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 2 | 07-10-2003 10:00 PM |
