help with finding premiere etc on our technomate box | |
| Regular Member Join Date: 20-01-2008 Location: Lanzarote
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w |
Please can anyone provide any help? I am living in the Canary Islands and I have got a Tecnomate TM 5500 ci and two set dishes at 28.2 and 19.2 East. We also have a T-Rex twin module cam with no card. I am a complete novice and would like some starting points. I would like to watch more premiere league and Spanish football and having visited LJs think the best way to go is premiere sport portal or galaxie sport but I have no idea how to receive them or if they are hackable. I also only know how to search and how to enter frequencies, like I said a complete novice. As I am just starting out any help will be greatly appreciated. | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | What size dish do you have? That may be a factor in determining where the problem lies. Robbo | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | The one dish is 1.2m and that is pointing at 28.2east. The other is a very small dish that is pointed at 19.2e. Thanks. | ||
| Super Moderator Join Date: 10-12-2004
![]() | Currently both Premiere, 19,2E, and Digi TV, Galaxy sports, 1W, are both open with patches and/or the Dragon cam. Can you enter your Dragon Cams menu, using your receivers remote, and please tell us what version of Predator is loaded. For full channel information, for premiere, check here: _http://www.lyngsat.com/packages/premiere.html You should also be able to find the Astra 1 footprint, on the site, to tell you what size dish you require for your location. | ||
| | #6 | |||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | )The Astra 1KR and 1L satellites will be an easier catch. Alternatively, get a bigger dish for 19.2E, a 1m looks more suitable, check with your local satellite shop. | |||
| The Following User Says Thank You to Robbo For This Useful Post: | mcdet8 (21-01-2008) |
| | #11 | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | Ive just looked in the local paper and there is a card programmer for sale. I dont think it comes with any equipment but it does say for updating firmware. Would you still advise investing in a cam 3 or will the cheap option work enough. Thank you for all your help so far. Thanks | ||
| | #12 | ||
| Amo Amas Amant Admin Join Date: 18-11-2004 Location: NW England (Siberia)
I would suggest you stick with the cas 3+ as what you have described could be anything and more than likely no good for what you require
__________________ War does not determine who is right, it determines who is left! Formerly toppervte33h whose six pack has turned into a keg Help support this web site by making a donation Or use other options to help support Sats UK Show Your Support by clicking the button ![]() Thank you. Freddie Flintoff is back | ||
| | #13 | ||
My System: technomate reciever 5500 ci super, astra 28.2 E and nilesat 7w | hi seen a few cas 3"s for £50 ... ive also seen a cheaper option a dynamite programmer plus.. would this update the firmware on a t-rex cam to the latest predator. thanks all Last edited by mcdet8; 22-01-2008 at 11:16 PM | ||
