Satellite Connection Question
Information exchange on digital satellite systems other than Sky
Old 03-03-2008   #1
My System: DIRECT TV
If cable connections are extended in the house by barrel type connectors will this degrade the Hi Def signal and video ?
DANO is offline   Reply With Quote
Old 03-03-2008   #2
rolfw's Avatar
Real name: Rolf
It will attenuate the signal slightly (depend how long you are extending by and the initial signal strength), but shouldn't affect the signal quality to any significant degree.
Rolf
Old 03-03-2008   #3
lifes not a practice run
4dbennett's Avatar
My System: Technomate diseq 1500ci+ and Humax Foxsat HD Acer Aspire 5315
Barrel connectors deplete the signal strength by 10%, i have two feeds off a four feed lnb and they are of the same length cable except one has a join with a barrel connector and the signal strength is exactly 10% lower, the signal quality is unaffected.
regards dave
4dbennett is offline   Reply With Quote
Old 03-03-2008   #4
rolfw's Avatar
Real name: Rolf
It won't be by a percentage Dave, it will be a fixed db loss, haven't measured, but I would guess one db at low IF and 2 at high IF. The percentage will vary depending on your original signal strength.
Just taken a couple of measurements and these are without barrel and with barrel connected to a 3m patch cable.
10719 mhz (IF 9750mhz) - 72.1db/microvolt without, 70.2db with cable and barrel connector, no difference in noise margin or BER.
12600 mhz (IF 2000mhz) - 63.2db/microvolt without, 60.1db with cable and barrel connector, no difference in noise margin or BER.
Rolf
Old 03-03-2008   #5
Robbo's Avatar
Real name: Mark
So that's worse case about 3dBs loss then, which means you lose approx 30% of the signal voltage you had on the input to the barrel.
Equal to about 10m of satellite cable.
Old 05-03-2008   #6
My System: ?
regards dave
I haven't tested a signal before and after the connection. However, there are some other parameters. If the connectors are not fitted to the cable properly then the signal loses its strength because of bad work.
If the connection is outdoors then it should be protected from rain.
tesla is offline   Reply With Quote
Old 05-03-2008   #7
4dbennett's Avatar
NICE %,s Robbo
dave
Old 05-03-2008   #8
Robbo's Avatar
Real name: Mark
NICE %,s Robbo
dave
Not nice no, but true.
20*log(0.7)=-3.
thus -3dB means you have 0.7 of what you had before, so you've lost 30% of the signal voltage.
or 3dB represents a signal power loss of 50%.
(10*log(0.5)=-3)
connection, question, satellite
[IMG] code is Off
