Blocking DC to LNB with capacitor
Information exchange on digital satellite systems other than Sky
Old 29-03-2008   #1
My System: Sky Digibox, 1.2m Dish, FreeSat Card
I am using a Technomate 1000D without an LNB to receive a signal that is being transmitted on the IF frequency (1.3 Ghz)
The aerial is a BiQuad that has an DC resistance of 0 Ohms so I have turned off the LNB power supply and 22 KHz in the setup.
The box works correctly under these conditions but fails to start up from a mains off/on situation.
If I power it up and connect the aerial afterwards it works fine but if I cycle the mains off and on, it will not start up until the the aerial has been disconnected.
I suspect that it does a check at startup to ensure that the LNB is not a short circuit.
To overcome this, an engineer has suggested that I put a capacitor in series with the aerial connection to block the DC to the LNB.
So my question is, what value of capacitor would you suggest?
Thanks for your attention,
Mr Happy is offline   Reply With Quote
Old 29-03-2008   #2
Gaza 1's Avatar
My System: 3Mtr Laser PF invacom .3 lnb and laser feed horn AD3000VAICP Cards Cams all the other Stuff Annie 204 Spectrum
DC Blocker
antiferance do a dc blocker f plug one side socket the other they are about an inch long price about £3-00 trade. i use these after the line amp which i place near the folded dipole on the beam for 23cm's
Gaza 1 is offline   Reply With Quote
The Following User Says Thank You to Gaza 1 For This Useful Post:
Mr Happy (29-03-2008)
blocking, capacitor, lnb
[IMG] code is Off
