Installing a system
Information exchange on digital satellite systems other than Sky
Old 01-05-2008   #1
erukus's Avatar
My System: a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8
Installing a system
Hi there I am thinking of insatalling a dish for a dreambox 600 i have never installed or bought a dish before and would like to install a dish with a motor. I was looking at this dish
_http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=47163&doy=1m5#overv iew
can anyone who knows tell me what they think apparently i can attach a motor to it also if someone could advise me on an lnb there are a few listed below the dish description and also what other equipment I would need. cables etc??? Thanks
erukus is offline   Reply With Quote
Old 01-05-2008   #2
Robbo's Avatar
Real name: Mark
Yes, that dish will attach to a Diseqc motor OK.
You can normally get a Moteck sg2100 for around £35.
Either of the single LNBs listed would do the job OK, although you may be able to get one cheaper online. I have found that the Inverto Silvertech 0.2dB outperforms the Fortec star one listied on Maplin.
Other kit you will need is some satellite coax such as wf100,f connectors,cable clips, 2 inch diam pole, T&K brackets and tape.
Robbo
Old 01-05-2008   #3
erukus's Avatar
Thanks what is your opinion on this dish I have chosen maplin due to free delievery 1 year gurantee and somewhere to return it free if something is wrong. Just wondering about the quality of this dish???
Old 01-05-2008   #4
erukus's Avatar
anyone know why my hyperlink was removed?
Old 01-05-2008   #5
mhku's Avatar
My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini
If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots
You're not allowed to post live links.
Use an underscore _ e.g.
_www.maplins.co.uk
You don't stop playing because you get old, you get old because you stop playing. Regras
Before posting in the Dreambox section please ensure you've read The Guide
Information is for educational purposes only
mhku is offline   Reply With Quote
Old 01-05-2008   #6
Robbo's Avatar
Real name: Mark
I have that dish and don't think it's too bad for it's size. I was able to pick up some of the weaker channels on 7W and 26E on it. The mount on the back is quite feeble though and the dish arm not very substantial, but once setup it does the job reasonably well.
Most of the satellite stuff from maplin is way overpriced. Take a look at the site sponsors and make a comparison.
The Following User Says Thank You to Robbo For This Useful Post:
erukus (02-05-2008)
Old 02-05-2008   #7
erukus's Avatar
Hi
I am wondering if I have a sky dish already installed with a cable coming from the dish to the wall. If i install a new 85cm dish can I somehow connect the cable from the new dish to the cable from the sky dish and have the two satellite dishes coming to the wall via the same cable i.e. the original sky cable. Also is the dreambox 600 equipped to handle two seperate dishes??? Cheers
installing
[IMG] code is Off
