help orbit sat digital receiver problem viewing | |
| Member Join Date: 21-06-2008 Location: cyprus
My System: i have xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . not tec knowledge at all ! scanned lnb nilesat. live in cyprus . please help |
i have orbit xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . no tec knowledge at all ! scanned lnb nilesat. instalation guy had never seen this type of box , said the signal was 99 % but still no picture. left me with no viewing .live in cyprus . please help lucy ![]() | ||
| | #2 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | Orbit transmit off 2 satellites. Atlantic Bird 2 at 8W and Eurobird 2 at 26E. The footprint map suggests your dish is on the small side for decent reception of 8W, so get the installer back to realign the dish onto 26E.
__________________ | |||
| The Following User Says Thank You to Analoguesat For This Useful Post: | lucyl17 (21-06-2008) |
My System: Technomate TM6800D & TM1000D+ receivers, Stab H-H90 motorised Triax 1m dish 42E to 30W. Fixed Orbital 1m on 26E, 2 x minidishes.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Yep, Cyprus looks to be smack-bang in the middle of the beam used by Orbit on Eurobird 2. ![]() _http://www.lyngsat-maps.com/maps/eb2_fixed.html
My System: i have xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . not tec knowledge at all ! scanned lnb nilesat. live in cyprus . please help | thanks so much for your help will call him back up.lucy | ||
| | #5 | ||
My System: i have xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . not tec knowledge at all ! scanned lnb nilesat. live in cyprus . please help | this is a second hand box , can anyone tell me does orbit offer free view channels and do i require a card for this ? thanks once again | ||
| | #6 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | Heres the channel list for Orbit on 26 _http://www.lyngsat.com/packages/orbiteb2.html As you can see theres a couple of free channels, but there are no ftv channels. Im pretty sure the Orbit boxes have a chip inside them so no card required, but you will need to resubscribe.
| The Following User Says Thank You to Analoguesat For This Useful Post: | lucyl17 (22-06-2008) |
| | #7 | |||
| Super Moderator Join Date: 13-08-2007 Location: Middle East - Israel
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | _http://www.lyngsat.com/packages/orbiteb2.html Check that your receiver has a CI Slot and can encrypt Irdeto 2 and Mediaguard 2 encrypted channels before ordering a subscription card. It will not be as cheap as buying it from "official" countries. | |||
| The Following User Says Thank You to HB13DISH For This Useful Post: | lucyl17 (22-06-2008) |
| | #8 | ||
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.4.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card ![]() He battled for 3 days against the Tux and won! Hurray!! | Sorry Analoguesat, same post almost typed at the same time. Except yours is more accurate about it being an Orbit box. | ||
| | #9 | |||
| Broadcast / RF engineer Join Date: 20-02-2006 Location: SE Wales UK
My System: 3.7m & 1.8m Prodelin, 1.2m Andrew, Loads of receivers, Orbit & showtime & AFN. | I have orbit myself and can tell you that the xd300 has a built in seca 1.5 card inside the receiver it is a sim card size card which is covered in epoxy glue and if the subscription has been canceled you will not be able to view any channels on the receiver not even FTA channels as the decoder will be blocked unless you get the decoder reactivated, So just to confirm no orbit subsciption = no FREE TO AIR or scrambled channels at all, Also with the xd300 if it is not set up on the correct default transponder in the menu it will not scan no channels at all and also euro-bird 2 25.5 east and Atlantic bird 2 8'w both have different orbit default transponder both use diff rent technical parameters you have to set it up correct but i would advise not setting a dish up for orbit on AB2 8'W as orbit is due to leave the satellite soon,
| The Following User Says Thank You to Rd100 For This Useful Post: | lucyl17 (22-06-2008) |
| | #10 | |||
My System: 3.7m & 1.8m Prodelin, 1.2m Andrew, Loads of receivers, Orbit & showtime & AFN. | You are correct both the philips xd300 and humax xd300 both have built in seca 1.5 sim cards, But orbit is now moving over to using real size irdeto 2 viewing cards which you can using in a irdeto receiver or cam, For new orbit customers orbit issue them with the new Humax xd200 receiver which is a new model which has bulit in irdeto and is ideal for use on the middle east irdeto providers and it also have orbit epg and will also work with showtime Arabia,
| | #11 | ||
My System: i have xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . not tec knowledge at all ! scanned lnb nilesat. live in cyprus . please help | thanks so much , does this mean i would need to subscribe to orbit have my dish re aligned and i could put a showtime card in\ would showtime then work as well \ could i just put a show time card in ? cheers so much lucy | ||
| | #12 | |||
My System: Sky UK family pack. FTA analogue & digital satellite from 5 fixed dishes (4.6E/5E/13E/16E/19E/23E/28E) Pace MSS100, Echostar IP3000VA (with dragon cam), Coship CDVB 2300A, Fortecstar Lifetime Ultra, Technomate TM-1000D, Dreambox 7020S, 2250kb ![]() The last noble sat warrior to fly the olden flag of Analogue | No. Put very simply the Orbit XD300 is useless to you unless you intend to subscribe to Orbit with it (via 26E). If you just want free channels to get you going and then think about subscribing later then you need a different receiver.
| The Following User Says Thank You to Analoguesat For This Useful Post: | lucyl17 (23-06-2008) |
| | #13 | ||
My System: i have xtra digital xd 300 salellite receiver box & 1 meter dish , all channells scanned ok nearly 500 but unable to view anything . not tec knowledge at all ! scanned lnb nilesat. live in cyprus . please help | Thank you for your time responding as you can tell i know nothing about satellite viewing ! . can you recommend a cheap box to buy that will give me free view channels . cheers lucy | ||
| | #14 | ||
| Member Join Date: 24-03-2008 Location: united kingdom
My System: none at present | Hi Lucy, Ive just got back from Cyprus and wanted to find out whats over there as Im moving there 1st Nov. I contacted Demontronics which is in Skoulli and he provides dish,receiver and installation..Card cost 48euro. You can then get several programmes with showtime and a few free ones as well. I did contact Holitec in Coral Bay as well and they are providing wireless freeway for broadband and by Nov/Dec they will be setting up freesat. all you need is a small dish. To contact them here is the email and phone number digby@holitec.eu phone 26821412 Good Luck hope you get sorted. Missing beautiful Polis already and only been home since Sunday night. | ||
