Fortec Star FS-4200 Help Please
Thread Tools Display Modes
Old 22-06-2008   #1
My System: Famaval 2.4m dish, Invacom 0.2dB LNB (single), Pace 430N
I have obtained from Maplins one of the above SD receivers. I find the
handbook minimal, although the receiver itself seems OK. Can anyone advise me how to get the receiver onto a specific frequency or channel. and how to get it to scan a range of selected frequencies (as opposed to scanning all channels on a selected satellite as the book details)?
Geoff
Sunny Cyprus
geoffreys is offline   Reply With Quote
Old 22-06-2008   #2
Llew's Avatar
My System: Triple Dragon with HDD/USB stick, Humax HDCI2000, Echostar AD3000ip & SR8700, Fortecstar 5100CIUltra, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. Diablo/Mrev Cams
Does this Fortec have a true blind scan feature? What does the 'Advanced' facility in the Menu give you?
__________________
Llew is offline   Reply With Quote
Old 22-06-2008   #3
Thanks for your reply Llew. I am not sure what a "true blind scan feature" is, but it is not mentioned in the "User's Manual" and I cannot find it by looking thru the Menus etc on screen. The Menu does not appear to have an 'Advanced' facility.
I take it from your message you have not got one of these receivers yourself (??),
Geoff
Old 22-06-2008   #4
Llew's Avatar
No, I don't have that model, so I probably can't help much, but I checked the features list over at Fortecstar, and it mentions Advanced as an option. I just wondered what delights it offered for as a scanning feature.
__________________
Old 01-07-2008   #5
My System: FS4200, iss 70cm dish,single passion lnb
I dont know if any of these tutorials might help ive just got a fs4200 but me think it will go back check the vent slots and see if a bunch of wires are up against a transformer cos it could well melt the wires i would like to know how you get on with it _http://www.ftavideos.com/fortec/cd/index.html
portly is offline   Reply With Quote
Old 02-07-2008   #6
Thanks for your reply. The Video Tutorials are for the Mercury II satellite receiver, not the FS-4200 like mine.
I have checked inside my FS-4200, all wiring seems OK.
Cheers.
Geoff
Cyprus
Old 02-07-2008   #7
Cheers.
Geoff
Cyprus
I only point to the site because most software isnt that different from model to model, it was just for general guidence Glad to no your fs is ok inside , mines going back
The best Gaz
fortec, fs-4200, star
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.2
