LNB Connection
Thread Tools Display Modes
Old 07-07-2008   #1
My System: Sky tv
LNB Connection
My present Sky + shotgun cable is connected to the number 1 and 4 outlets on the LNB, I am going to replace the cable as I am moving the TV into another room is there a reason why the terminals 1 and 4 are used and 2 and 3 are empty ? could I use 1 and 2 instead as there is only one SKY + BOX in use.
Thanks for any info
neil41 is offline   Reply With Quote
Old 07-07-2008   #2
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
You can use any! THey probably used 1 and 4 'coz it's easier to attach the cables if you have big fat fingers :-)
pgh13 is offline   Reply With Quote
Old 07-07-2008   #3
Information Exec
satelliteman's Avatar
My System: 43cm Dish, Sky Plus v2, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover Discovery ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N
Yes look at a Quad as four separate LNb's in one unit
__________________
A Detailed DiSEqC Motor Installation Set Up Guide HERE
Motor Installation 'Quick' Reference Guide also HERE
[IMG] code is Off
Forum Jump
All views and information expressed in users' communications and profiles represent the opinions of the users concerned and do not represent the views of Satellites.co.uk. All images and news content are believed to be in the public domain, except where otherwise stated. Forum software by vBulletin® Version 3.7.3
