Problem with Showtime in Iraq | |
| Member Join Date: 13-08-2008 Location: iraq
My System: I have a dual card reciever, connected to 2 sattalites, am in iraq and can unscramble showtime arabia |
-------------------------------------------------------------------------------- Good afternoon all. This is my first post. Am hoping to find some help. I am in iraq and had a guy set me up a sattelite system. It is a Star dual card reciever, that has some sort of sofware update in it. This was connected to nilesat to recieve showtime arabia. A second sattelite was then connected to unscramble the channels. It worked really well. I have moved to a different location and am trying to set the system up again. The problem i have is that i dont know what sattalite the second sat needs to be connected to to unscramble showtime. Could anyone help me?? am trying to get set up for the new premiership season | ||
| | #2 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Moved your post from a totally unrelated thread. Unfortunately probably only the guy who set it up initially will be able to tell you what to do, can you not ask him? These systems normally connect to the internet for update.
__________________ | |||
| The Following User Says Thank You to rolfw For This Useful Post: | arontaylor (15-08-2008) |
My System: I have a dual card reciever, connected to 2 sattalites, am in iraq and can unscramble showtime arabia | Thanks for that. Am new to this... Nah cant get hold of him. The system is a mystery to everyone... Worked really really well though. It unscrambled everything.. Once i find out how it all work, i will post it, so people can try the same... Sooooo frustrating at the mo.... | ||
| | #4 | |||
Blog Entries: 3 My System: Sky+, DB 7000s, Gemini 4.3 in flash, Var on USB stick. Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Unaohm EP313, Swires Annie 204 Spectrum, Rover ST-4 Spectrum. | Well I can't see that you will be able to guess at the satellite, are there no clues in the receiver setup menu, it should have the second satellite listed in the DiseqC table.
| | #5 | ||
My System: I have a dual card reciever, connected to 2 sattalites, am in iraq and can unscramble showtime arabia | I thought there must be something like that in the setup. Thats great, thanks for the advice...am still kicking myself, for not checking... only 2 days till the premiership starts again...mad rush!!!! | ||
