Vantage receiver, 2 pin mains plug ?
Thread Tools Display Modes
Old 01-09-2008   #1
leecovuk's Avatar
My System: TM 6900 HD Combo Super receiver; multi-lnb and 2 dishes for Astra1+2, Hotbird, Hispasat.
Question Vantage receiver, 2 pin mains plug ?
Hello,
I've just received a new Vantage receiver but it has a pre-attached mains lead with a 2 pin mains plug on it.
Should I attempt to push the 2 pins into a standard UK 3 pin socket or do I need some kind of adaptor?
Thanks a lot,
Lee
leecovuk is offline   Reply With Quote
Old 01-09-2008   #2
Don't force it in a UK socket, either buy an adapter or cut the 2 pin off and fit a normal plug.
__________________
Mickha is online now   Reply With Quote
Old 01-09-2008   #3
leecovuk's Avatar
Thanks Mickha.
Looking at wikipedia, it seems to be a 'europlug'. The 2 pins very slightly bend in towards each other. Vantage are made in Germany, I believe.
I think I'll fit a UK plug on it myself. Which rating fuse should I put in? The back of the unit says:-
AC 90 - 250V ~,
50/60Hz, MAX. 25W
Of course, any advice given to me here, undertaken at my own risk.
Thanks again,
Lee
Old 01-09-2008   #4
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
3 amp
With the top of the plug off & the connectors towards you its blue to the Left, brown to the Right
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
Old 01-09-2008   #5
rolfw's Avatar
_http://www.euronetwork.co.uk/acatalog/Euro_to_UK.html These guys sell some handy converters.
__________________
Rolf
Donate
Old 01-09-2008   #6
leecovuk's Avatar
Thankyou all.
3 Amp sounds right in line with this part of the wikipedia page :-
"Europlugs are only designed for low-power (less than 2.5 A) Class II (double-insulated) devices that operate at normal room temperature and do not require a protective-earth connection."
I'll see if I have a 3 amp fuse first .. if not I'll resist and look for an adaptor tomorrow.
Would be handy if my local Asda have them in their electronics / electrical department !
Lee
Old 01-09-2008   #7
leecovuk's Avatar
Turns out I have a pack of 3 amp fuses and a spare 3 pin plug ...
let the wiring modification commence !
Last edited by Robbo; 01-09-2008 at 11:13 PM Reason: Altered words to avoid being wrongly categorized by google
Old 01-09-2008   #8
Site administrator
Make sure its not plugged in when you cut it! If you forget you get a huge shower of blue sparks and ruin the blades on the cutter
I speak from experience
__________________
Analogue forever!
Old 02-09-2008   #9
leecovuk's Avatar
Sounds nasty :O
All went well. Took me ages to do the cable and wire the plug, not having done it for ages and using a pair of scissors to bare the cable (!) ... oh and I so carefully wired the 2 wires the wrong way round before checking and realising and having to do it again. Even though I indeed knew 'BLue - Bottom Left, BRown - Bottom Right'. Can I use being tired as an excuse?
Not really my thing fiddling about with little wires!
Thanks again for all your 'on the spot' advice last night!
Lee
[IMG] code is Off
Forum Jump
