Finding the best.... | |
| Member Join Date: 26-04-2008 Location: Portsmouth,Hampshire
My System: Nothing Yet..Pending |
Ok so I'm going to have a go at fitting my new motorized system over the weekend its a Technomate 5400 CI +.I'm a little confused as to with satellite I should be trying to line up with.I'm in the Portsmouth area and I have read so many threads about which satellite to locate first.I hear 'Thor 1' is a good one to set on first.Any info would gratefully be received. | ||
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox. | Yes, Thor 0.8W, assuming your dish is sufficient. Your longitude is very very close to 0.8W, it is always best to use your nearest to due south satellite. Just send the dish to 0.8W using USALS and away you go, and tune into 11325H, and adjust for best signal quality.
__________________ | ||
| The Following User Says Thank You to Robbo For This Useful Post: | g60edition (11-09-2008) |
| Information Exec Join Date: 07-05-2007 Location: South Midlands, UK & Lanzarote, Canary Islands, Spain
My System: 43cm Dish, Sky Plus V2, Thomson DSI6210 Sky+160, Thomson DSI4214, FRACARRO PENTA 85cm, Invacom Twin, Moteck SG2100a H-H DiSEqC Motor, TF5000CI, TM-5200D, Sling Media, Rover ST-4, Rover SDM-1s, 57E to 58W, Tecatel 1.35m fixed on 28e, Pace D5430-N | Take a look at these first: Detailed motor install guide Setup Guide for DiseqC motor - Pictorial & Quick guide QUICK REFERENCE MOTOR INSTALLATION SETUP GUIDE - Pdf
__________________ - .....A Detailed DiSEqC Motor Installation Set Up Guide HERE Motor Installation 'Quick' Reference Guide also HERE Satellites UK site Advertisers - | ||
