Receiver Recommendations
Thread Tools Display Modes
Old 17-09-2008   #1
My System: 80cm dish with three LNB's pointed at Astra 1, 2 and Hotbird
Hi, I have a dish set up receiving three Satellites, Astra 1, 2 and Hotbird. Now I want to add a receiver which will receive all the channels from all three sats, and be able to receive TNT as well, which is, I think, Viaccess 3. I may also wish to add Canal+ later which is also Viaccess 3.
The TNT recommendation is the STRONG STR 6420, but I do not know if it will do all the above, and I am pretty sure it has only one Viaccess card reader.
Since I am strictly a newbie can someone suggest what I should look into?
Many thanks
Andrew
fdservices is offline   Reply With Quote
Old 17-09-2008   #2
My System: Satellite Dish 1.6m Hotbird 13E, DreamBox 7000S with Gemini 4.5.0; Dish 1.2m Amos 4W, Nokia 9600S; Nokia 9800S; Hauppauge Nexus-S PCI Card
He battled for 3 days against the Tux and won! Hurray!!
Have you considered the DreamBox 7025S?
You can have two different tuners, one for satellite DVB-S and the other for terrestrial DVB-T.
I think that it has a CI slot and also a card reader so that should take care of the official smartcards.
Also add internal HDD for recording.
Selection of satellite channels would be accomplished by using a Diseq switch.
__________________
Abolish the Yes Israel Package Basic Subscription and give subscribers true flexibility.
More details
here
HB13DISH is offline   Reply With Quote
Old 17-09-2008   #3
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
What you want to do is is almost impossible. There are over 10 different packages on those three sats using a variety of encryption systems. Some of them also requiring a dedicated receiver. The Dreambox/linux receivers may work with a fair few of the offical provider cards, but maybe not all of them though.
I suggest you do a lot of digging, to establish which packages you really want and find out if any specific hardware is needed, or whether a hardware CAM or Dreambox can be used.
Old 17-09-2008   #4
Sorry Robbo, but I think that the O/P is interested only in the TNT package and/or the French Canal+, unless he really means ALL the encrypted channels and not only FTA.
So basically two card readers should be enough.
__________________
More details
here
Old 17-09-2008   #5
Robbo's Avatar
Yes, you are probably right
Old 17-09-2008   #6
Yes that's right TNT and possibly Canal+
Thanks for the replies I'll take a look at the Dreambox first.
Andrew
Old 17-09-2008   #7
The ads refer to "2 x Smartcard-Reader" is this the same as a Viaccess card reader, or perhaps all the readers are the same? Sorry for my ignorance, but I will learn.
Andrew
Old 17-09-2008   #8
Andrew
The smartcard readers use software CAM emulation, something like CCcam in order to decrypt the official card of say Canal+.
There should also be a mention of CI CAM slot, where you insert a PCMCIA module like Viaccess and then insert the official smartcard inside it.
You then need to select the type of cam from a dropdown list.
I suggest that you download the 7025 user manual and specification sheet and go over all the details.
Good Luck
__________________
More details
here
Old 17-09-2008   #9
OK I will, thanks
Andrew
Old 17-09-2008   #10
Strong SRT 6420
I had a closer look at the Strong SRT 6420 and it looks like a cheaper option for you with a price tag of 149 Euro or less.
It has only one embedded Viaccess CAM, but will give you TNT sub for 4 years.
You can buy 2 receivers (for the second CI slot) and it is still a cheaper option than 7025. But check if the remotes can be set so as not to activate one another.
__________________
More details
here
[IMG] code is Off
Forum Jump
