Dish Paint ?
Thread Tools Display Modes
Old 27-09-2008   #1
aileen's Avatar
My System: Technomate 6800 HD. Motorised 88 cm dish Installed by Robbo Mac computers
Dish Paint ?
Hi guys. In respect for my neighbour who hinted he thought it stated in the deeds that all aerials should be 'In the loft' I intend to spray paint my largish disk a colour similar to the background bricks.
I presume I cannot use metallic paint and seek info on which paint to use. (aerosol). A source would help assuming the standard 'plastic' in DIY shops is not suitable TIA.
aileen is offline   Reply With Quote
Old 27-09-2008   #2
Site administrator
Analoguesat's Avatar
My System: Sky UK. FTA analogue & digital satellite from 5 fixed dishes (5E/7E/9E/13E/16E /19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S
Tell him its not an aerial - its a dish and it wont work if its in the loft.
Matt car primer will do fine.
__________________
Analogue forever!
RIP BBC2 analogue on all Scottish Borders transmitters, switched off 0031GMT November 6th 2008
Final analogue switch off from all Scottish Borders transmitters - BBC1 ITV C4 & C5 - 0010GMT November 20th 2008.
The Following User Says Thank You to Analoguesat For This Useful Post:
aileen (27-09-2008)
Old 27-09-2008   #3
aileen's Avatar
Thanks for that but: Primer probably ain't brick colour. I assume you mean cellulose but that might react with the paint that's on it. ? My neighbour is the sort who would have a word with the LA and I guess they would still 'suggest' that two dishes and a terrestial aerial on the chimney is a bit much.
Old 27-09-2008   #4
Site administrator
Cant you get brown car primer??
If not matt aerosol paint of some sort should do.
__________________
Analogue forever!
aileen (27-09-2008)
Old 27-09-2008   #5
Robbo's Avatar
My System: TM6800HD+TD110+StabHH90 motor,TM1000D+Orbital 1m Multifeed 16E,23E,28E.DigitAlB movies. A Bigsat BS-S77CX and a Sky Dodgibox.
Some matt plasticote paint from B&Q should do it. I'm pretty sure that's what I used on my Triax to paint it green. Since your dish is dark, it should only need a light spray over.
The Following User Says Thank You to Robbo For This Useful Post:
aileen (27-09-2008)
Old 28-09-2008   #6
Oldgeezer
johnsattuk's Avatar
My System: Topfield 5800 Echostar3000,DB7000, Relook 400S, Humax HDC2000, 55cm Fibo Gregorian dish with waveguide and Motek 2100 mod, 90cm Fibo Gregorian dish, 120cm Fibo Gregorian dish on a 1224 motor with waveguide
I used 'Hammerite' , mixed copper, gold and a touch of red to get as close to brick as I could. It's not aerosol, but hammerite is very easy to apply.
After the paint has hardened just matt the suface with 'scotchbrite'
__________________
Oldgeezer
johnsattuk is offline   Reply With Quote
The Following User Says Thank You to johnsattuk For This Useful Post:
aileen (28-09-2008)
Old 28-09-2008   #7
Enigma1 Dreamboxer
nanochickin's Avatar
My System: Dreambox DM7020, Orbital 1m Dish, MTi 0.2dB Twin lnb, Technomate SG2200 motor. Rover DM16C Digimax & Rover DL4 Meters.
As AS has already stated its not an aerial
Does it say anything in the deeds about satellite dishes ?
If not you can legally put upto a 1m dish on your property. The best bit about it is there isn't a fat lot he can do about it
I've had a similar run in with my neighbors in the past over my 2 dishes.
I got round it buy installing the biggest size i could get away with under current law. I have since under the cover of darkness increased both dishes in size
There is now a 1m and a 90cm dish up which the neighbor hasn't said a thing about
I'm always under the assumption that neighbors who complain have nothing else better to do with their sad little lives other than make peoples lives a misery
Nano
__________________
I'm a Satellitehelp refugee
nanochickin is offline   Reply With Quote
The Following User Says Thank You to nanochickin For This Useful Post:
aileen (28-09-2008)
Old 28-09-2008   #8
Robbo's Avatar
Yeah, put them up at night nano, when no-ones looking, works a treat.
Another option I have used is to spread the dishes around a bit, so that one neighbour can only see the one dish. For example aileen, your minidish could be moved so that it can't be seen from your neighbour's property.
aileen (28-09-2008)
Old 28-09-2008   #9
aileen's Avatar
He's not a bad old fellow. Has probably slept since comment and forgotten it. I have to agree dishes are a bit ugly on the low level of a bungalow. Definition as mentioned above: It would never come to it but in a Court a Judge would probably lump dishes and aerials all as 'Antenna' and define them together for the purpose. This being my guess. I cannot find if there is precedent of this. It concerns me that, as I understand it, motors cab be a bit noisy should I have one fitted. Don't want to push my luck.
Old 28-09-2008   #10
rolfw's Avatar
Can you take a photo of your dishes and upload it aileen?
__________________
Rolf
Donate
Old 28-09-2008   #11
Robbo's Avatar
The Motecks with nylon gears are not really that noisy. I find that from inside that you have to strain your ears to check that its actually moving sometimes. My metal geared Stab, when I had it on the side of my house,was not too bad either.
aileen (28-09-2008)
Old 28-09-2008   #12
aileen's Avatar
Will dig out the camera tomorrow
Old 28-09-2008   #13
aileen's Avatar
Pic of Dish to be painted
Taken by Robbo who fitted dish for me
Old 28-09-2008   #14
Amo Amas Amant Admin
Topper's Avatar
Well
It really all depends upon yourself, how much you want to hide it but this is an example of how far you can take it Aileen
Spot the Dish
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 29-09-2008   #15
My System: Sky; Raven 90 with LNBs for 1W, 7E, 13E 16E and 19E; Technomate 1500 and Kathrein Analogue Receivers
Can't remember correctly but I think that the planning regulations do indeed lump them as 'Antenna'; can't immediately recall a judicial or other precedent either.
Sorry that whilst not contributing to the painting conundrum, I have a request. Could you and Robbo kindly put me out of my curiosity by confirming what satellites the four LNBs are receiving?
bigtee is offline   Reply With Quote
Old 29-09-2008   #16
Robbo's Avatar
From left to right, 19E,13E,9E, 1W bigtee.
bigtee (29-09-2008)
Old 06-10-2008   #17
rolfw's Avatar
Read the sticky for planning guidelines, UHF TV aerials are not counted, it is dishes only and yours comply with size and number restrictions.
__________________
Rolf
Donate
Old 06-10-2008   #18
Design Engineer/Installer
pedro2000uk's Avatar
My System: 75e-75w C & KU, 36v diseqc Anlg to HD Channel Master C120 dishes, stbs, lnbs, motors, too much to list
The planning regulations do call satellite dishes... antennae - typical civil servants writing regulations like arranging so much spaghetti on a plate ready to either confuse or be unravelled...
You can have two of these satellite antennae up to 1m and 60cm on a property... Literally.. To me that could mean an LNB with antennae up to 1m & 60cm inside the lnb and the reflector/ dish can be anything you want ... they don't mention it...
The planning site does show favoured positions for satellite dishes (they ave pictures of em- look more like a load of balls to me) .... not on a ground floor though.. X ..oops.. (bungalows excluded)
BTW... Nice neat looking job...
__________________
xxxxo0O0oxxxx
ONLINE STORES THAT HELP SUPPORT THIS FORUM
pedro2000uk is online now   Reply With Quote
[IMG] code is Off
Forum Jump
