poor signal strength & quality
Information exchange on digital satellite systems other than Sky
Old 20-12-2008   #1
My System: Sky dish with quad LNB, 3 sky receiver and 1 Silvercrest SL65/12
Hi All,
I have a sky mini dish currently running 3 digiboxes from a quad LNB. All are fine. I am trying to add a Silvercrest SL65/12 receiver to the 4th output, but am only getting 32% signal intensity and 11% Signal Quality.
The cable run is approx 40 metres to my workshop away from the house. Is this the problem, or do I have a connection issue?
Any help would be appreciated
BobD is offline   Reply With Quote
Old 20-12-2008   #2
satelliteman's Avatar
Real name: Paul
Welcome,
Problem might well be down to a poor termination of one or both of the F connectors. I'd first fetch one of the sky boxes down and connect that to the cable to see if all is ok. This will eliminate any set up issues with the Silvercrest receiver.
A 40m cable run won't give you signal loss to the extent of no signal at all
satelliteman.
An Installers Choice
Follow us on
Old 20-12-2008   #3
Question
Thanks Satellite man, I will try that, but can you please explain to a novice what you mean by termination of the F connectors?
Old 20-12-2008   #4
Robbo's Avatar
Real name: Mark
Putting the connectors onto the cable ends.
Watch out for strands of wire from the braid, touching the core. Also core should protrude a couple of millimetres or so from end of connector.
Also proper double screened 75 ohm satellite cable should be used, preferably wf100 or similar.
The Following User Says Thank You to Robbo For This Useful Post:
BobD (20-12-2008)
Old 20-12-2008   #5
Real name: Paul
Termination: The connection of a suitable coaxial connector to a cable, termination or final connection.
In simple terms, sticking the connector on correctly
satelliteman.
Follow us on
Old 20-12-2008   #6
Robbo's Avatar
Real name: Mark
No, this is termination
Old 20-12-2008   #7
Tried digibox on feed, no signal. Checked connection at receiver, OK, I guess it's back up on the roof tomorrow!
Thanks for your help Guys
Old 20-12-2008   #8
Real name: Paul
Sounds like it the cable F connection on the LNb then .....or a duff port
satelliteman.
Follow us on
The Following User Says Thank You to satelliteman For This Useful Post:
BobD (20-12-2008)
Old 20-12-2008   #9
Mod and septic resident
Channel Hopper's Avatar
Before you do that, try substituting a Sky box for the Silvercrest, just in case it really is the new receiver.
Old 21-12-2008   #10
Hi All,
Clambered onto roof, renewed connection at LNB, Bingo! perfect picture.
Thank you all for your help.
Old 21-12-2008   #11
Real name: Paul
Good news
satelliteman.
Follow us on
poor, quality, signal, strength
[IMG] code is Off
