Good quality small discreet aerial’’Information exchange on digital satellite systems other than Sky | |
| Member Join Date: 18-12-2008 Location: London
My System: I have a Sky + box but can’t use it just like everyone else that uses a communal stat dish I don’t have a spare outlet unless I pay X amount Computer just a Sony running Microsoft Explore on BT broadband |
Hi all I live in a block of flats only two story with a communal Sat and Arial combined. To receive Sky + I am fitting a new dish’ and at the same time I am going to try and fit a new aerial to feed our three rooms Can anyone advice me on a good quality small discreet aerial’’ I live in North London Barnet Regards Tomcat ![]() | ||
| Regular Member Join Date: 09-12-2008 Location: east Anglia
My System: motorised dish and technomate receiver | This _http://www.screwfix.com/prods/65934/Electrical/TV-Range/Aerials-Fixings/Megaboost-Aerial-With-4-Way-Amplifier-Fixing-Kit-22-dB-Gain might suit you. "J" | ||
My System: motorised dish and technomate receiver | Hiya I posted a non-live link but it has been put in the queue to be checked. Try s c r e w f i x part number 65934 "J" | ||
| | #4 | |||
| Sky Remote Breaker... Join Date: 05-01-2006 Location: Near Pendle Hill, Lancashire
My System: Mostly gathering dust cos there's no room for dishes here... :( The Sleepy Hollow pollracle has spoken! |
![]() But anyway, just buy a minidish with a Quad LNB off Ebay | |||
| I think your car looks funny too...... Proud owner of a satellites.co.uk cap & T-Shirt... ![]() (though the latter no longer fits due to my ever expanding waistline!!!) Resident KIRBY Vacuum nut... ![]() | ||||
| | #5 | |||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Might also be worth checking if you have permissions to install any aerials/dishes on the building first. | |||
| | #6 | ||
My System: I have a Sky + box but can’t use it just like everyone else that uses a communal stat dish I don’t have a spare outlet unless I pay X amount Computer just a Sony running Microsoft Explore on BT broadband | Thank you very much (J) for all your help All the best tomcat | ||
| | #7 | ||
Hi all Can you have a Sat dish and a TV aerial Side by side on a chimney or is there a set distances they must be apart I thank you Tomcat ![]() | ||
| | #8 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | As long as the dish has a clear line of sight. You can mount the dish onto the lashing bracket. Don't drill into the chimney. | ||
| | #9 | ||
Hi Thanks for the reply ‘ just one thing why not drill into the chimney it’s a big thing about 4 foot square tomcat | ||
| | #10 | ||
My System: Zone1, DSI8215 SkyHD, Thomson DSI4214, TF5000CI, Dreambox DM800 HD PVR - Nab BH0.12, TM-5200D, Gibertini 104cm, SNH-031, 36v Actuator, Vbox-II, 42°E to 30°W, Sling Media, Televes H45 Digital Processing Analyser, Satlook Micro+G2 NIT, Rover SDM 1s | Normally Single skin, poor brickwork, poor mortar, not strong enough, not professional. | ||
| | #11 | ||
| Regular Member Join Date: 21-04-2007 Location: nottingham
My System: chaparral montery 40 fully loaded ehcostar ad3600ipvia 3 dishes zone 2 / 1 mt motorized / 2.3 m motorized | you can drill in to the chimney but make sure it is in very good condition first bricks and mortar i have seen where people have fitted dishes on chimney stacks i.e. sky dishes bolted to a couple of bricks and you get a phone call my sky has gone off can you please sort it for me you go round and ask them where there dish is on the stack you are told you look up and ask where all there is is a chimney with a hole in its side where the dish bracket has ripped the bricks out and no sighn of the dish any where saw this once on a 3 story shop in nottingham on a very bussy main road with a 60 cm annalog sky dish hole in the side of the chimney and no sighn of the dish any where never did find it lets face it a sky dish falling from 50 ft with 3 bricks attatched to it very dangeruse if it had landed on some one it would have killed them for sure fairly modern stacks are single brick thats a no no for sertain older chimneys are 9 in brick my chimney is from front to back is 3 ft and from end to end is 8 ft with 5 flues in a row and i have a 1 m motorized dish on it been there for about 20 years but it is on t and k brackets the t bracket is on the chimney in the loft and the k bracket is on the chmney just above the roof with a 6 foot scaffold pole going through the roof with lead collar on it to keep the weather out t and k brackets should be fitted the other way round with the k brack at the bottom as it the k bracket that takes all the weight but didnt have much room but as there is over 6 feet of chimney above the brackets didnt realy matter but still check it every month to be on the safe side | ||
| | #12 | ||
My System: I have a Sky + box but can’t use it just like everyone else that uses a communal stat dish I don’t have a spare outlet unless I pay X amount Computer just a Sony running Microsoft Explore on BT broadband | Thanks maybe I should look at some alternatives can you suggest a good method for a 60cm dish Tomcat | ||
| aerial’’, discreet, good, quality, small |
