Can I connect 2 receivers using t he loop through option?
Information exchange on digital satellite systems other than Sky
Old 11-01-2009   #1
GreenmanBelg's Avatar
My System: 1 x CM 1.2m matching C120 feedhorn and Invacom 0.3db twin output LNB.50 degrees East to 42 degrees West.1 x CM 1.2m AZ/EL mount matching C120 feedhorn and twin output Invacom 0.3db Humax VACI 5300 Old Panasonic Digibox with IRL $ky sub. Coship FTA
Question Can I connect 2 receivers using the loop through option?
I should know this but the need never arose before. Bought the Smart MX 4 L this week for feeds etc, its fine for that but I would like to use my Topfield as well I like the Topfields software. The Topfield will be the main receiver so dose that mean the Topfield is antenna in and the Smart is feed from the Topfield?
If the Topfield is on and I switch off the Smart I see the Topfield and visa versa?
Thanks in advance.
Regards JD Belgium.
GreenmanBelg is offline   Reply With Quote
Old 11-01-2009   #2
Design Engineer/Installer
My System: 75e-75w C & KU, 36v h-h /36v & diseqc actuators / diseqc -USALS motors / Anlg to HD Channel Masters C120s dishes, stb's inc echo3000, lnbs, meters, custom polar mounts & elevation/incline actuator conversions...
Thanks in advance.
you've got it JD...
but...
....you do find that some stbs just don't like to be linked like that, so just try it..
also...
....both should be able to control the motors*./. diseqc switches... and you can have both on -on the same band - usually with no real loss too. (1 or 2 to record from etc..)
*if you use diseqc 1.2 to 36v.... then you need to line up the diseqc numbers per satellite but don't alter diseqc motor positions with the second stb (unless you want to tweak it the odd time)
some stbs don't allow editing of the diseqc positions ... in that case leave the motor off on the 2nd and just use the first to control the motor.
pedro2000uk is offline   Reply With Quote
The Following User Says Thank You to pedro2000uk For This Useful Post:
GreenmanBelg (11-01-2009)
Old 11-01-2009   #3
Wink
Originally Posted by pedro2000uk View Post
also...
Thanks Pedro, thats fine as I use a separate positioner. I'm going to try in an hour or so. I'll report back. The Smart will be powered off when not in use.
Regards JD Belgium.
Old 12-01-2009   #4
Need extra cables so thats it for another day.
Regards JD Belgium.
Old 12-01-2009   #5
Thumbs up
Got the needed cable, all working.
Thanks very much Pedro.
Regards JD Belgium.
Old 12-01-2009   #6
no problem...
connect, loop, option, receivers
[IMG] code is Off
