Fortec Star- scanning problemInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 30-01-2009 Location: Suffolk UK
My System: fortic star |
Hi, This is my first post, I have to confess to being a complete newbie to satelite tv. I have a fortic star passion HD receiver and 60 cm dish. I'm very impressed with quality of reception from Astra 2 free sat. I have a question, I previously had an older, pre free sat, fortic star digital receiver, Lifetime II, this gives good results on some channels on the same dish but I am unable to get all the channels that the new HD receiver gets. As both boxes work off the same dish, I assume they are receiving the same satelite, (Astra 2), so is there any way I can get the older box to receive all the free sat channels? I apologise if this is posted in the wrong place or if it is too dumb. John. | ||
| | #2 | |||
| Guest
Posts: n/a
![]() Anyway, you just need to update your Fortec Star's 28E Transponder list. If it is the same model as my Wife's Rx, it has Network Scan, which should take a lot of the work out of it. Try enabling that first. If it brings up all the stuff you want, fine. It isn't a true Blind (or Auto) Scan, but will add in all Transponders used by BSkyB (which includes all the FTA Channels anyway). But if it doesn't, manually correlate (Add, Edit or Delete) your stored Transponder list with these _http://www.flysat.com/28east.php Then scan. Great fun keeping older Receivers up to date! Not. Edit: If that Rx is newer than ours, it might actually have Blind/Auto Search/Scan .................. If so, job done! Obviously you'll only get the Standard Definition Channels, but that's 98.7365% of the total. | |||
| Member Join Date: 17-01-2009 Location: surrey near guildford
My System: Passion+ with fortec 65cm | jon.clem I suggest that you start a new thread in the freesat forum as you will get more response whhops good rai uno has found you he is very helpful | ||
| | #4 | |||
The reason I wanted to get this box going is because I have a holiday home in Brittany France and I still have the old analogue dish - perhaps you might know one other thing - assuming the fixing is the same, can I put a digital LNB on the old analogue dish or do I need a new dish as well. Many thanks - I really appreciate your help. Regards, John. | |||
| | #5 | |||
My System: fortic star | Regards, John. | |||
| | #6 | |||
| Guest
Posts: n/a
Obviously a later model than my Wife's box (Actually, I wonder if Wives can be updated too ................ )As for the old Dish, it'll probably have a 40mm collar mount (My "pig-sty" Analogue Dish has), so any cheapo Universal LNB should fit quite happily. Don't forget to ensure the Dish is aligned to the right Satellite cluster - Analogue was 19.2E. Mods: Thanks for creating the separate Thread. | |||
| | #7 | |||
| fortec, problem, scanning, star |
