Line Amplifier does not increase the qualityInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 12-03-2007 Location: dubai
My System: NSS-6 |
HI, I have installed DishTv in my building. I am living in Dubai. It is a 3 storey building and the dish antenna is connected centrally. Tenents in the 3rd floor receive good signal & strength. I am in 2nd floor. One of the vertical frequency is very weak, which is 12727/V/27500. I bought a 10db line amplifier and connected near the receiver. After I placed the line amplifier, I loss some percentage of quality what I was receiving earlier. Can any one help me, how to improve the quality & strength. Thanks and any help would be much apprecaited. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No point in inserting a line amplifier at the receiver end, as you have nothing much left to amplify, you need to either install a larger dish, or put the line amplifier/amplifiers nearer to the dish so that you are amplifying good low noise signal. | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Yes, putting an amplifier where the SNR is already insufficient, will not improve it, it will always make it worse. This is because of the noise figure of the amplifier itself. The noise figure logarithmatically expresses the ratio of the input and ouput signal to noise ratios of a device, which for amplifiers is always worse on the output as more noise is always added. | ||
| | #5 | ||
My System: NSS-6 | Thanks a lot for your replies. Dish has LNB with 4 output which directly goes to Mixer. Then mixer distribute it to each flats. Do I have to place the amplifier near the Dish Antenna or the mixer. I already have 120CM dish. Thanks, | ||
| | #6 | ||
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | I think you are going to have to put it after the "mixer" because if you put it before, you will effect everybody elses system too, and without knowing the system design, you could end up overloading the "mixer". After is safest as it will only effect your feed. If the SNR there is insufficient, then there is something badly wrong with your distribution system. | ||
| | #7 | ||
| Specialist Contributor Join Date: 09-09-2008 Location: Republic of Georgia
My System: Covering 30W-105.5E range, two motors, C and Ku band. Various receivers/cards/cams/etc. | 120cm is not "big" by any means. "big" starts at 180cm at least... | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | I would normally install a four way IF amplifier before the multiswitch (I presume that's what you have). | ||
| | #9 | ||
| Regular Member Join Date: 20-04-2006 Location: Lost in the night
My System: ? | In order to find the best point to connect the line amplifier you have to measure the signal's level at the start and the end of the cable. If the signal of the LNB is strong then the amplifier connected next to LNB will saturate the amplifier. | ||
| | #10 | |||
| There is a very fine line between "hobby" and "mental illness" | ||||
| amplifier, increase, line, quality |
