Remote control for satellite receiverInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 10-06-2008 Location: Normandy, France
My System: Elap motorised satellite dish and digital receiver disecq 1.2 |
Hello Hope I'm posting this in the right place! I have an Elap Ellypse digital satellite receiver, and the remote control has stopped working. I opened and cleaned it, replaced batteries, etc, still no joy. Does anyone know how I can get a replacement? I've tried looking for the brand name without success. It's a french system - do remote controls work in different countries or are they specific? How do you know that a generic remote will work with your machine? Any advice much appreciated! | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Are you entirely sure it is the Telecommander that is the problem, as opposed to the IR Detector on the Receiver? If you are sure, then try abrading the battery cradle terminal points with fine sandpaper or similar (holding it upside down so any loosened corroded bits falls into open space, not into the Telecommander!). I have a Kaon RC that requires this treatment on occasion (and a Mobile Phone, ditto!). Also, are you using the Remote in a room with energised CFL Lighting, as these new fangled Low Energy lamps have been known to upset simple IR systems. Finally, do ensure you don't use Rechargeable Batteries as the terminal voltage is often just a smidge too low. | ||
| Member Join Date: 17-07-2005 Location: Plymouth UK
My System: Echostar 2110 Technomate 5200D Porty 2 S Crest SL65 1m H-H Lidl 80cm on TM2200 Lidl 40cm on Omnisat. |
Check the IR output of the remote by pointing it at a CCTV system, digital camera or Mobile phone camera. It should show up very well. | ||
hi again I have tested the remote control with a digital camera, and it seems to be dead. If anyone can make any suggestions about a replacement, I'd be really grateful. Many thanks | ||
| | #5 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Did you try cleaning the Battery Cradle terminals? | ||
| | #6 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Ha! By pure coincidence my disabled neighbour asked me to look at the Remote Control for his kitchen Stereo yesterday afternoon - guess what? The batteries had leaked slightly and exacerbated corrosion of one of the cradle terminals. Thorough clean up and now all working. The problem is the power demands are so very low for these batteries that they sometimes get so old that they physically degrade before "going flat". | ||
| | #7 | ||
My System: Elap motorised satellite dish and digital receiver disecq 1.2 | Thanks for this, but I have checked the battery cradle -- all perfectly clean, no sign of corrosion at all. Looks like the remote control really is dead! | ||
| | #8 | ||
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | Ok, fair enough - I have no idea where you can get a replacement from, though. | ||
| The Following User Says Thank You to Tivù For This Useful Post: | fla_independent (08-07-2009) |
| | #9 | |||
| Archived Member Join Date: 13-08-2007 Location: Middle East - Israel
I would go for a good universal remote, and if you have a friend/neighbor/relative/etc. who has the same model, you can take your universal remote to his place, and try to "teach" the universal all or most of the functions using the good remote. Logitech has an excellent remote, but rather expensive. Other than that, buy a new receiver. Here is a link _http://www.logitech.com/index.cfm/remotes/universal_remotes/&cl=us,en | |||
| | #10 | |||
Thank you for your help with this | |||
| | #11 | |||
| The Elap Ellypse is an FTA receiver, and you should be able to buy a new one instead as they are quite cheap, even a second hand. Can't recommend any universal remotes, and there is always a chance that it will not recognize your receiver model. Better invest your money on a new receiver. Do you have at least any access to the receiver using the front panel? Alternatively, try to get your remote working by a professional. They can't charge you much as a new remote from well known brands costs between 10-30 euros. Should take the receiver as well to the shop so that they can test it. Suspect either IR transmitter diode or the chip inside. | |||
| The Following User Says Thank You to HB13DISH For This Useful Post: | fla_independent (09-07-2009) |
| | #12 | ||
| Member Join Date: 28-05-2007 Location: Berlin, GErmany
My System: FTA receiver | Hi, Search in Ebay K | ||
| | #13 | |||
| control, receiver, remote, satellite |
