nokia media master 9200 problem:HELP~
Information exchange on digital satellite systems other than Sky
Old 16-08-2009   #1
My System: nokia 9200
Exclamation nokia media master 9200 problem:HELP~
i have a nokia media master 9200 at home!!
everything was ok till i had some relatives for 1 week at home!!
one of the childs changed the pin code from 1234 to unknown number and now i am not capable to change anything at the 9200!!
is there any way to reset the 9200 or i have to throw it away???
ps sorry for my English
Sirkaik is offline   Reply With Quote
Old 17-08-2009   #2
zorbua's Avatar
My System: Dreambox 8000 HD Dreambox 800 HD Clark Tech 5000 HD EchoLink 700FTA
Try Master Code 147258 should be ok
zorbua is offline   Reply With Quote
Old 18-08-2009   #3
the code is 4 digit!how i am supposed to give 6 digits?
could you help me!
Old 24-08-2009   #4
zorbua's Avatar
could you help me!
Four digits is when its operational normally....to unlock it you have to apply the mastercode than afterwards you can again apply 0000 or change it to whatever you want...What I don't know is whether you have to enter ''Menu'' etc, etc.. before applying the code...check on Go_gle by typing 'Nokiamedia master 9200s' and look for mastercodes
Old 26-08-2009   #5
Trust1's Avatar
Pull the powercordplug , keep pressed the up and down buttons on the front and put the plug back .
In the display appears "ERASE" , now leave the up and down buttons .
Now the password is set to 0000
A few personal settings could be changed NOT your channellist
My soldering iron is smoking all the time .
Gr. Trust1
Trust1 is offline   Reply With Quote
The Following User Says Thank You to Trust1 For This Useful Post:
zorbua (01-09-2009)
Old 01-09-2009   #6
zorbua's Avatar
Didn't know that - thanks - whats the master code for than?
9200, master, media, nokia, problemhelp
[IMG] code is Off
