Linux SystemsInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 10-12-2007 Location: Glasgow
My System: Technomate 5400ci motorised system, Basic Sky Set Up, Cyrus HiFi, 3 drumkits, 1 wife. |
Had my Technomate 5400 for about 2 years now and i'm thinking of upgrade to a hard drive/hd/linux model but i'm a little confused about the advantages. So some beginner questions. Whats the main advantages of the linux based systems, can you get on the web and stream movies ect. The technomate i have i use softcams all the time, well only when needed-does the linux systems give you more access to channels in other words do the get you more than nagra. HD...will i be able to get freesats hd channels. Are the built in HDs good or prone to freezing anything like that. AND Finally.....whats the best brand or make to go with, the technomate is a joy. thanks | ||
| Specialist Contributor Join Date: 07-05-2008 Location: NW, Ireland
My System: DM 600-S, AB IPBox 9000HD, Moteck SG2100, Fracarro Penta 85 dish, + some puters | The only Linux box that I know of which claims to be capable of streaming from the internet is the AB IPBOX 9x series. Although this feature has yet to be implemented in its software. If you intend going down the Linux box route, you had better be happy to sacrifice a big chunk of your spare time. Tinkering with them will eat up the hours. Ive had a few SD Dreamboxs and never had any problems with playback of recorded programs. I've not read of anyone having trouble with HD boxes either. There are softcams available for all of the Linux boxes. One of the better ones is CCcam which is intended for the Dreambox. It will read most cards across all the different encryption platforms. The main advantage is probably card sharing. | ||
| Regular Member Join Date: 15-06-2008 Location: Birthplace of Television
My System: Cuberevo Twin HD on a 85cm motorised Fracarro Penta dish. Superior Dark Motor. Inverto BLACK Ultra Single lnb (IDLP-SINL40-ULTRA-OPP) | I own a Cuberevo (ipbox 9000). The picture quality is fantastic in both HD and upscaled SD. There are various third party firmware to choose from and yes, you can stream using mutlicast throughout the house from the box, play media files from your PC (DIVX & MPG) or from the internal hard disk if you have fitted one. Very please with mine. I moved from Technomate, would recommend it m8. | ||
| linux, systems |
