Lost audio on Astra 19.2E channels / Digiquest P2000
Information exchange on digital satellite systems other than Sky
Old 28-09-2009   #1
My System: Digiquest p2000 (antique!)
Hi All,
I have a very old Digiquest P2000 Viaaccess/SECA embedded receiver. Basically I only use it now fixed to one channel, TV Polonia on Astra 19.2E.
I used to have it connected to a motor but now it's via a single LNB to the Astra 19.2E location, with only a handful of channels installed.
Problem is, the other day I noticed that the sound was 'glitchy'. This was the case across a few bouquets / channels, even though the picture quality was superb with no blotches / squares appearing that indicate poor signal. It's become so bad that the sound doesn't really exist anymore and you just get snippets of sound, despite the clear perfect picture.
I retuned the channel bouquet, then just channel with info from lyngsat.com (VPID, Audio PID etc etc all included) and still the same problem. Likewise just giving frequencty, SR and polarization it's the same problem.
I've interrogated the menu system and the Astra 19.2E signal strength is showing 70%. I know this clearly isn't 100%, however it picks up the pictures just fine, in fact they look clear as day and it's as if the sound has been turned down.
Any ideas anyone? Perhaps dish needs to be moved slightly? I'm wary about doing this given that the picture quality is perfect -- I thought that with a DVB signal it's either all there, or all not, and with a perfect picture you'd expect perfect audio?
Thanks in anticipation folks.
polak1 is offline   Reply With Quote
Old 28-09-2009   #2
satelliteman's Avatar
Real name: Paul
Are you experiencing any other channels with audio problems?
satelliteman.
An Installers Choice
Follow us on
Old 28-09-2009   #3
Hi - yeah all seeem to be the same so it's not a one-off thing.
Old 28-09-2009   #4
Real name: Paul
Have you tried a receiver reboot.
satelliteman.
Follow us on
Old 28-09-2009   #5
Hi - yes a few times three-pin resets as well as regular standby on/off, but no use.
In your opinion is 70% signal strength (albeit with perfect picture) sufficient for Hotbird in the south of UK? Thanks!
Old 28-09-2009   #6
Real name: Paul
Certainly sounds ok, no pun intended
Would of thought it was a receiver fault rather than a dish alignment problem.
satelliteman.
Follow us on
192e, astra, audio, channels, digiquest, lost, p2000
[IMG] code is Off
