King dome frustration
Information exchange on digital satellite systems other than Sky
Old 28-09-2009   #1
My System: King Dome 13" on RV
Hello,
We have an RV with a 2 year old King Dome 9630. It worked well for a long time but now when we make a trip I can locate the satellite easily but after about 6 hours I lose the signal and no amount of trying will get it back.
Then when we return home I can again easily locate the satellite.
It seems that something in the dish might be getting hot.
I am absolutely lost and no one seems to be able to offer any suggestions.
Help!!
rlandram is offline   Reply With Quote
Old 28-09-2009   #2
Amo Amas Amant Admin
Topper's Avatar
Hello
Welcome to the forum rlandram
Just remember, some of the terminology is unknown to us as we are predominantly a European forum. So this is some kind of satellite reception unit that is fitted to a kind of motorhome?
I would guess you are correct in your assumption of the overheating, is the unit DC powered from the battery or is it running through an inverter?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 28-09-2009   #3
My System: 1M Motorised Dish, DM 500s, Digital+, Sky+, TDT
h*tp://www.kingcontrols.com/rv.asp
redout is offline   Reply With Quote
Old 29-09-2009   #4
Thank you for your response. It is powered by 12 Volt DC through either the inverter or the batteries.
I called King Dome and the technician thought it could be one port of the LNB but could not be sure.
Old 29-09-2009   #5
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Is it possible to remove the cover? is the LNB recognizable? Looking at the spec it says dual LNB. Are both in use or could you select the other output?
pgh13 is offline   Reply With Quote
Old 30-09-2009   #6
I believe it is a dual input. Would selecting the other input possibly help?
Ron
dome, frustration, king
[IMG] code is Off
