technomate remote knackered ?Information exchange on digital satellite systems other than Sky | |
| Member Join Date: 03-08-2007 Location: ascot uk
My System: tm 1500+ super, macbook pro, 360, wii. pc |
hi i'm keen to get my remote to work again, just wondering how can i do a hardware reset with out the remote (hopeing to ge it working that way), or would repatching the receiver work ? | ||
| Member Real name: Kelvin Join Date: 04-01-2009 Location: southcoast uk
My System: tecnomate 5600 CI USB super / 5500 ci super/ 1500ci super dragon trex cam, several dead cards sky subscription and box 1.2 metre motorised dish 65 cm sky dish | Hi Elspuddy are you sure it is the receiver that is the problem? are you able to borrow a remote to try or check yours on another receiver of the same type? if you take your remote to a t.v. engineer they should be able to test it, most have a remote tester. this will tell you if it is the remote or the receiver. hope this is helpful. Teach | ||
| Toute Ronde Bon Oeuf Real name: Gordon Join Date: 29-05-2009 Location: North Yorks Moors
My System: Triax 1.1m and Orbital 80cm Motorised Dishes. Various fixed Dishes. Eclectic selection of Digital and Analogue Receivers. Complex switching and distribution that SWMBO cannot fathom. Nor me. | If the Remote Telecommander hasn't been used much in the months leading to its demise, it is not uncommon for one or more battery terminals to corrode as the result of galvanic action and/or battery leakage. Remove batteries, clean contacts with edge of a screwdriver blade or similar, taking care to hold the device so that any loosened bits of corroded material don't get inside. Fit fresh batteries. | ||
| The Following User Says Thank You to Tivù For This Useful Post: | Elspuddy (11-10-2009) |
My System: TM6800HD, TM1000, TM600 Linux,TM5200, TM2200 motor, Triax TD110 dish + Fortec 85cm. Meter=Satlook Micro+G2 NIT | Have a look at the remote through a digital camera (on the lcd display), you should see a a white flashing light coming out of the emitter. | ||
| | #5 | |||
![]() while cleaning the eage's off with a small scruedrive i saw that one of the negitve springs have fallen off. any one got some gum ?? need the mettle bit :P | |||
| knackered, remote, technomate |
