Help Rolf!!!
Thread Tools Display Modes
Old 19-08-2002   #1
Member of the Big Dish Club
Robbiewright's Avatar
My System: Sky plus V3 and a 50 inch plasma screen.
Help Rolf!!!
Hi Rolf,
I know this is the wrong board to post this But I thought I might find you faster here. I need the link to that satelite calculator thing oor a list of frequencies and tranponders for nilesat.
Many thanks
Greetings from farao land Robby
Robbiewright is offline   Reply With Quote
Old 19-08-2002   #2
rolfw's Avatar
No problem Robbie, the Swedish Microwave calculator is HERE
You can find the channel details for Nile sat HERE or HERE
Happy hunting.
__________________
Rolf
Donate
Old 19-08-2002   #3
Just not my day today. Rolf, I wanter to send you a P.M but I can't till I edit my profile. How do I do that?? I'v done it before but am lost now.
Old 19-08-2002   #4
Mod and septic resident
Channel Hopper's Avatar
The SMW calculator will not really help resolve issues with digital transponders, though its a good start for approximate dish size
What do you have on your roof in Cairo Robbiewright ?
Old 19-08-2002   #5
rolfw's Avatar
Go into user cp at the top right of the page Robby, you'll find that you can edit profile and options such as PM receipt, plus add an avatar etc.
__________________
Rolf
Donate
Old 19-08-2002   #6
I am in a bit of a bother. I am it a friends house in the back blocks if Egypt, he has a cheep box to get BBC World on Nial Sat, it was working fine till I touched it. I wanted to see if there was anything else out there to watch on nile sat. I wteeked the dish, did more scans, tweeked and scanned some more and got him a few more shopping channels and some aribic talk shows about 75. All was fine till the last tweek and scan, now I only have 35 channels of rubbish and no BBC world. I found the transponder with the link you gave me and there is jusn no sign of life there althow other transponders are working. HELP, He is going to kill me.
Old 19-08-2002   #7
rolfw's Avatar
Double check that you haven't inadvertently disabled the 22Khz tone switch Robbie, that transponder could just fall into the upper band of the LNB.
Its on a Horizontal transponder, so check the horizontal alignment, the vertical may be correct, so just try tipping the dish Slightly up and down.
__________________
Rolf
Donate
Old 19-08-2002   #8
The 22 k thing was on "universal" I tried on and off but on change. one of the other transponders I found working was also "H". I have rocked the dish a bit but no change.
Old 19-08-2002   #9
Are you sure you have not twisted the LNB slightly in its housing.
If you can receive any tranmissions on the same polarity as the BBC then ensure yuo peak the LNB on one of these first.
Can you check any neighbours systems for the BBC ? There is an outside chance they may have changed frequency in the past day which may or may not be logged on Lyngsat or Satcodx
Old 19-08-2002   #10
thay may have changed frequency but it would have just happend now. just as I was scanning. I will see if I can find some one else with bbc and see if thay still have it.
Old 19-08-2002   #11
rolfw's Avatar
OK, Universal is what it should be set at, I was actually looking at BBC ?World Service and not BBC World, and so the transponder is probably on the lower band anyway.
If you set the transponder to 11.766 H and just try and tweak the dish on that setting, you should get results.
You can't be too far off, so don't panic, it should only be tweaking, may also be worth looking at the skew of the LNB and make sure that is correct, this can also be done by trial and error.
__________________
Rolf
Donate
Old 19-08-2002   #12
Still no life, the other transponders are booming in and usaly BBC dose too. I was watching bbc then did another scan and lost it all. I think I must be going mad or that turned it off the second I did the scan. Havn't found anyone else with a dish yet to see if it is still there.
Old 19-08-2002   #13
rolfw's Avatar
In the setup menu can you actually get a signal strength from an individual transponder and if so are you getting a reading on the BBC one?
__________________
Rolf
Donate
Old 19-08-2002   #14
it's about 20% but that dosn't change even if I put my habd over the LNB.
Old 19-08-2002   #15
rolfw's Avatar
That sounds really odd Robby, have a look and see in the LNB setup what the LO frequencies ar listed as, they should be 9.750 low and 10.600 High, I am also assuming that it is a universal LNB.
The other thing to check is the H and V transponders immediately below and above, to see if you have a signal there.
__________________
Rolf
Donate
Old 19-08-2002   #16
there are a lot of transponders that arn't working, looking at the list again there are a lot that never were eather.
Old 19-08-2002   #17
rolfw's Avatar
Is there any pattern apparent Robby, mostly Vertical or all in one frequency range etc. Also are you sure that the transponders/channels that you are receiving are definitely from the same satellite and that you haven't innadvertently moved to an adjacent one.
__________________
Rolf
Donate
Old 19-08-2002   #18
It's cominf from Nial sat, I get transponder 7, at least he gets BBC world service raido now.
Old 19-08-2002   #19
rolfw's Avatar
Can you get any of the vertical channels Robby?
__________________
Rolf
Donate
Old 19-08-2002   #20
Old 19-08-2002   #21
rolfw's Avatar
Just looked at the SMW calc and it would appear that the Skew on the LNb should be around 45 degrees.
__________________
Rolf
Donate
Old 19-08-2002   #22
I am getting some V channels, the only pattern I can see it that what he had before, he now dosn't and he now has what he never had before and ther are still som transponders that i have never seen working.
Old 19-08-2002   #23
I'll go and have another look. It's very hot on the roof today.
Old 19-08-2002   #24
rolfw's Avatar
Well there are two satellites up there in that position and I'm wondering whether one is slightly declined in orbit, so that you can either get one or the other.
In which case you may need to move a bit to find the others.
Do the transponders you can get seem to be in the higher range?
__________________
Rolf
Donate
Old 19-08-2002   #25
just looking at the channel list on the box and the one on the link you gave me. It seems to have found a blocked sky news ans fox from some where. I don't see them on the internet list.
[IMG] code is Off
Forum Jump
