Portuguese TV-Help PleaseInformation exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 16-06-2004 Location: Stoke on Trent
Hi, Rtpi is finishing transmission in the next few weeks on analogue Hotbird 2, it's started transmitting already on Hotbird 4, em Banda Ku, digital 13°E Frequency: 10722,88 MHz Polarization: Horizontal FEC: 3/4 Symbol Rate: 29.9 Ms/s The thing is what system will I need as I haven't got a clue and around how much will it cost? Thanks Obrigado Jane | ||
| Ex Arcade Bandit Join Date: 23-02-2004 Location: In the spare room.
| Hi Jane I don't think it has started transmisson yet, but when it does, assuming it will still be free to air on hotbird you will just need a digital fta satellite receiver, which you should be able to get for around £100 or less, and if your current dish has a universal lnb, you should be ok. Hope this helps prof | ||
| Moderator & General Globetrotter Join Date: 01-01-2000 Location: North West UK & Algarve Portugal
| Boa Tarde Jane, See-:http://programas.rtp.pt/canais-tv/rt...ao.php?canal=5 For more information on the change to digital. Also available on Astra 19.2E -: ASTRA 1 E (Digital) P. Orb.: 19.2 Este Freq.: 11567,5 MHz Pol.: Vertical Symbol Rate: 22000 FEC ¾ | ||
| zansi | |||
| | #5 | ||
| Ola Zansi! I have already seen that whats written on RTP, at the mo I am still on analogue, i am asking what kind of system will I need and can I keep the dish I have outside already an 80cm one or will it all have to be new! sorry for soo o many questions but I dont really understand. Cumprimentos Jane | ||
| | #6 | ||
| You need a digital receiver a FTA version is OK for RTP, but why not get one with CI slot then you can "experiment" with other channels? Your dish should be OK, but may need to change the LNB to a Universal (needed for digital) Get a copy of "what satellite" from your newsagent, look through for the best prices. A FTV digital should be available for less than £100 or a CI digital for not much more. | ||
| zansi | |||
| | #8 | ||
| The chances are the dish can be moved 6 degrees left to the new satellite, but a small chance something might be in the way to interfere with it. See if theres anything likely to foul the new position (wall, tree, gutter) before parting with the cash | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #9 | ||
| Jane It depends how long you have had your dish, if your lucky you might already have a universal lnb on the dish which is suitable for both analogue and digital | ||
| | #10 | ||
| Hi Prof the dish is the best part of 9 years old so maybe will not have a universal Inb. Thanks for the help, no doubt I will be in contact again soon to let you know how I go on. | ||
| | #12 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Have a look at www.sateuropa.co.uk one of our sponsors, they have a couple of very reasonable CI receivers in their list. | ||
| portuguese, tvhelp |
Similar Threads | ||||
| Help!!!!!!! Manhattan Plaza ST200 | twindish | Receiver software, international Section | 4 | 30-06-2006 05:12 PM |
| Bem vindo ao Portugeuese forum de satélite | Rod Hulls Aerial | Questões Frequentes. FAQs | 62 | 10-01-2006 11:51 PM |
