Max.dish size
Information exchange on digital satellite systems other than Sky
Old 30-06-2004   #1
Max.dish size
Hi All
What is the max.dish size you are allowed to install on a wall?I live in Essex.
I would like to install a 1M motorised dish on the back of the house with 2 M pole.Do I have to ask the council approval before install it?It would not obstruct anyones view.I would like to do everything legal.
Quick reply would be much appriciated.
Thanks in advance.
benblueeyes
benblueeyes is offline   Reply With Quote
Old 01-07-2004   #2
Jaffer's Avatar
My System: Samsung A300W with component output Hotbird & Astra2
Upto a metre ok. You need permission if its over a metre.
Every little helps and a little help goes a long way!
Jaffer is offline   Reply With Quote
Old 01-07-2004   #3
Dazed and Confused Mod
PaulR's Avatar
My System: Various digiboxes, broken Nokia 9800S, numerous analogue boxes. My lovely little lappy, HP Omnibook 6100
Actually I think you'll find that the limit is 90cm. If you live in a conservation area, a listed building or have conditions laid down by your landlord it could be less (or even prohibited).
Strictly speaking the 90cm is measurable in any direction so, unless you've got a prime focus dish, a nominal 90cm dish is taller than 90cm - about 98cm depending on the make. To stay strictly within the law you need to have a maximum of 90cm vertically which means an 80cm in practice.
Having said all that most people can't tell the difference between 90cm and 1m from a distance.
I suppose the big question is; how well do you get on with your neighbours? Also, how visible would it be from the road?
PaulR is offline   Reply With Quote
Old 01-07-2004   #4
rolfw's Avatar
Real name: Rolf
In real terms you can get away with 1m, but the rules are 90cm. If you tell anyone who asks about it that it is a 90cm, bearing in mind that they can't easily measure it, you'll probably get away with it.
Rolf
Old 01-07-2004   #5
rolfw's Avatar
Real name: Rolf
Snap PaulR.
Rolf
Old 01-07-2004   #6
BGonaSTICK's Avatar
You are all very bad boys.
I have a nice legal 88cm Triax.
Only because it would hit my neighbours fence on 30W if it were a 1M!
Be interested to see what it actually measures vertically...
Hang on, I'm going to put my slippers on and stagger out there now in the dark... wish me luck...
errrr.... 96cm.
I guess I'm a bad boy too.
Old 01-07-2004   #7
Hi all
It is 1M channel master dish.It will be installed on the back wall,almost center of the wall.Back of my house at the far end of my back garden 70 Feet away next house gable end.So they can't see it.My house is semi & situated in a cul de sac.Further inside my garden wall tall conifers 10 of them & hardly anyone can notice it.Only next door neighbour who is bit of a funny man& he may question about it.I've old 80 cm mesh dish(analogue lnb)& rusty.
I am going to get new dish installed end of the month,hopefully.I do not want remove it if anypone repot to council.Just wanted to be sure.
Thanks to all for the answers.
benblueeyes
Old 01-07-2004   #8
Hi PaulR
It is 1M channel master.As I live in a cul de sac & my house is semi. it can only be seen from the side of the house & inside the rear side garden wall I have tall conifers..Next door neighbour is a funny old boy.He may report to council,I do not know.
You think I should ask the council?
benblueeyes
Old 01-07-2004   #9
rolfw's Avatar
Real name: Rolf
If you ask the council, it will cost you whatever the local planning fee is and you still may not get it, better to perhaps have a chat with your neighbour and tell him that you are removing the old eyesore and replacing with a nice new 90cm dish, he almost certainly won't be able to tell the difference.
If you go the council route, you might as well get permission for a 1.2m dish, will pull in that little bit extra.
Rolf
Old 01-07-2004   #10
jimbo's Avatar
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
errrr.... 96cm.
I think your neighbour's a member on here mate, didn't he tell you?
Jimbo
jimbo is offline   Reply With Quote
Old 01-07-2004   #11
BGonaSTICK's Avatar
Funnily enough, they moved last week, and the new neighbours just had Sly installed yesterday, right alongside my multi-dish arrangement.
The engineer was giving my Triax a real good eyeball, and I'm reading his mind as he thinks 'Hey by the look of it, this bstard next door is definitely having some large portions of C*nax, and I wouldn't be surprised if hes doing a bit of S2 decrypting under the stairs n'all'.
... or he might just have been thinking 'only another 72 minidishes to do before knocking-off time... must be careful not to install one properly'....
Old 02-07-2004   #12
Is it legal to have a >90cm dish if you mount on a floor/grass? I.e. not on a wall or roof.?
jknights is offline   Reply With Quote
Old 02-07-2004   #13
rolfw's Avatar
Real name: Rolf
Technically makes little difference if it is a permanent fixture, bolt it to a wheelbarrow and they would have a hard job enforcing it.
Rolf
Old 02-07-2004   #14
Do you think I would rather have a smaller dish not 1M on the wall?
ben
Old 02-07-2004   #15
rolfw's Avatar
Real name: Rolf
Well I have an 80cm on my motor and receiver quite a lot, but there are times when a bigger dish would be an advantage.
Rolf
Old 06-07-2004   #16
I've part exchange my unused 1M Channel Master Dish for a 90CM Channnel Master(Satellitesuperstore)+Delivery&Collection charge.I've contacted the local planning office& they want £110.00 start with for 1M dish.Therefore I choose 1st option.Install 90CM & hope for the best.They are collecting/Delivering it on Thursday.
Thanks everyone for their advice.I would not have KNOWN the law otherwise.
Will post the results very soon & may ask more questions,CAMs etc
ben
Old 06-07-2004   #17
Clearing up doubt
Yes it is definately 90cm the limit and also one dish which many people seem to overlook. But just incase you are interested the government page for the regualtions is at:
http://www.odpm.gov.uk/stellent/grou...an_606331.hcsp
billieuk is offline   Reply With Quote
Old 09-07-2004   #18
Smile
Hi all
I am about to get my dish installed.The installer left a drum of cable, Rg6XXXX ,semi air spaced & 4 core cable for motor so I could run the cables from the loft to the receiver.
I've a drum of ct100 semi air spaced & a drum of form filled ct100.The question is which cable is the best for the installation ?
By the way Satellitesuperstore has exchange my 1M for a 90CM.It will be a legal setup.Thanks to all for the advice.
Many thanks in advance.
ben
Old 09-07-2004   #19
rolfw's Avatar
Real name: Rolf
I almost exclusively use foam dialectric cable now, providing that it has the good quality copper braid and foil screen, then go with the foam.
Rolf
Old 09-07-2004   #20
Supporting Advertiser
southernsatellite's Avatar
Yah, as I found out today a 80cm is crap at receving Spice Plat at 1 degree west, I really need a 1.2.
southernsatellite is offline   Reply With Quote
Old 09-07-2004   #21
Thanks rolfw.
I was going to use foam filled.Yes, it has quality copper braid & copper foil screen as opposed to other two types I've mentioned.Further, foam cable shows its quality & semi rigid.I am going to run the cables on Sunday & in about 10 days times chap would install & tune the receiver(Technomate 5500ADPCI).
By the way this THE BEST SAT.FORUM.Fast & excellent answers.
I may be answer questions once I've get to know the sytem !!!!!!!!!!!! I hope.
Many Thanks
ben
Old 09-07-2004   #22
Yes, I would like to have either 1 or 1.2M.But you can't have it on the wall(front or rear).
90cm is the legal limit on the wall to be legal.What can you do?It is the law.I know that now because I've asked the planning dept.
Old 09-07-2004   #23
rolfw's Avatar
Real name: Rolf
Oh well, you can always try for planning for a larger dish later on, see how you get on with this one in the meanwhile, there's plenty out there to be getting on with.
Rolf
Old 11-07-2004   #24
Hi rolfw
Once I get this system set-up,I assume I need a card or two.It has dual DVB CAM slots(will take Viaaccess,Irdeto,Seca,Nagravision,Conax compatable CAMS etc,but not supplied).What is the best way to go about.I am fine with programmers & PCs as that what I mainly do as an electronics enginner(full time job).Please give me a clue.
Many thanks.
ben
Old 11-07-2004   #25
rolfw's Avatar
Real name: Rolf
I seem to remember there being a firmware patch for the technomate to enable the entering of keys, but aside from that, a dragon CAM, or Matrix revolutions CAM along with a Titanium card or two would give you a useful setup.
Rolf
maxdish, size
[IMG] code is Off
Similar Threads
No idea what size dish do I need for getting Astra 2D in Sicily? ynot62 Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 07-12-2004 12:05 PM
Astra 2d..South Sweden, which size dish please! Rabbit Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 89 15-08-2004 11:06 AM
Astra+Hotbird dish size CB65 DISH SETUP: Single sat, Multi-Sat & Motorised systems 12 30-04-2004 12:40 AM
Dish size for Thor 2/3? mrdaveb Digital systems 4 03-03-2004 11:27 AM
Dish Size. RogerP Sky Digital (BSkyB) and Astra 28.2 East General 1 23-06-2003 08:52 AM
