splitting 1 coax to 2 boxes
Thread Tools Display Modes
Old 21-08-2004   #1
D4ftpunk's Avatar
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B.
can i use a bnc T connector to split my sat coax to 2 boxes, and will their be any signal loss or anything ?. also can i plug 2 coax's into 1 input somehow so i can recieve 2 sats at the same time using 2 dishes and 1 card/box ?
D4ftpunk is offline   Reply With Quote
Old 21-08-2004   #2
BGonaSTICK's Avatar
No.
Yes.
Yes.
You can use an A/B switch with a little loss, to switch one LNB between two receivers, and a 2-way diseqc switch to switch 2 LNB's across one receiver.
__________________
Old 21-08-2004   #3
D4ftpunk's Avatar
i know i can use an A/B switch but i literally mean a seemly switch, like auto? so i have 2 sats on 1 reciever permanently with no manual switching needed
Old 21-08-2004   #4
BGonaSTICK's Avatar
You can only really have 1 receiver connected at a time, as each would try to supply a controlling voltage to the LNB, so a physical switch is the only way to eliminate one of them from the equation. Hence A/B switch. Looking the other way, where you have one receiver and two dishes, or LNB's that would work fine using a diseqc switch, which uses the power supplied by the single receiver, along with diseqc commands, also sent by the receiver to switch betwen the two LNB's, highband, lowband vertical and horizontal polarisation.
STICK
__________________
[IMG] code is Off
Forum Jump
Similar Threads
'Free-to-air' powering growth of satellite TV boxes net1 Daily Satellite and Broadcast industry News 0 21-10-2004 08:18 PM
TopUpTV supported boxes and iDTVs PoloMint Terrestrial Television, Digital and Analogue 0 03-03-2004 12:23 PM
Two boxes, one LNB Robbiewright Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 4 01-03-2004 09:59 AM
F2V, Changing Boxes & Sky + Carlos Sky (UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 9 27-01-2004 07:59 PM
Freeview boxes Satdude Terrestrial Television, Digital and Analogue 0 06-08-2003 10:40 AM
