can someone helpInformation exchange on digital satellite systems other than Sky | |
| Specialist Contributor Join Date: 18-12-2004 Location: no mans land
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | well the simple answer is buy a viewing card but this time of the year i'd just look at buying 6mth's subscription + make sure your reciever or cam is viacess2 compatable as i'm sure thats the encription system | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | what set up have you got cams etc | ||
| | #6 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | well it should work i have a technomate reciever mr mrev +dragon cams no art card though as multivission 8 + tps star show 4 live games a week + all the rest with a delay so if you hav'nt paid 4 the art card yet it might be worth looking at other longerlasting options the mrcams are cheeper than art cards now and you would have the bonus of getting films etc aswell | ||
| | #8 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | sorry m8 forgot to mention you have to keep on top of the files for the cams if you stay on line for five mins i will check to see if a fun card and cheep programer still works with my embeddedsoftware as you will need this to update your cam any way so it might be worth you buying them first and yousing next years subscription on a cam | ||
| | #10 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | latest fun files dont work so you would need a cam +card writer and fun card6 the choices are endless but you can unlock some expensive packages so i would take a think about it as subscription 2 art will only last so long this is why i started the hobby football now im addicted i have a motorised system and with my selection of cams and cards get pretty well most games (the misses hates it though)if you are unshore just ask and i will help as best as i can | ||
| | #12 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | what is it loaded with when you put it in your reciever what does it say in the menu | ||
| | #14 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | you write to the card put the cam in the recierer go to the menu go to the cam if it is a reloaded cam click on it then in the next menu click on upgrade firm ware then insert cards when prompted if its a dragon cam load card insert card into cam and turn machine on go to menu click on cam and click on dragon loader and let it load | ||
| | #16 | ||
My System: two sky+amstrad boxes technomate5500ci+ with 80cm motarised dish irderto cam mr mrev +dragoncam blue tit numerous fun cards infinity pheonix compaq and dell on wirelessrouter | no problem m8 | ||
