LNB questionInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 01-01-2000
I'm about to change LNB. The current LNB has a ridge on the collar so it can not move forwards and backwards. The new LNB has no marking or ridge on the collar, so the question is does the distance from the dish to the tip of the LNB make a difference? The new LNB (MTI blueline) would be able to move backwards and forwards about 50mm within the LNB holder. Thanks in advance for any help. Barry | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | You should notice a small difference in the signal strength and quality between the two extreme positions Barry, so it is, like adjusting skew a little bit of trial and error. | ||
| On quality dishes the feed is separate to the LNB and is matched to the shape of the antenna. In this case there is a defined distance to the dish On LNBs that have integral feeds the feedhorn is a compromise to allow reasonable illumination of a large number of dish sizes. The focal point remains the same, but the need to move the LNB in and out gives you a trade off between efficiency of the feed and the illumination of the dish. Without knowing what dish you have its not possible to give a beeter idea as to the degree of success | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #5 | ||
| The dish is an 80cm offset aluminium grey mesh dish. I can't remember the make as I bought it about 4 or 5 years ago. I'll have a look tonight to see if there is any markings on the dish to identify it. The LNB is an MTI blueline 0.6db universal LNB (just takes the coax and no other connections). Barry | ||
| lnb, question |
Similar Threads | ||||
| MM software version question | geokar | Magic Module | 3 | 27-02-2004 12:51 PM |
| Forgive the stupid question, but . . . | mulls74 | Digital systems | 4 | 11-11-2003 11:08 PM |
| Question | Mark Fardelli | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 1 | 18-08-2003 11:00 AM |
| Small Question about recieiver | fruitbat | Digital systems | 3 | 10-07-2003 08:10 PM |
| Question | Razor | The Meeting Place | 7 | 07-07-2003 09:30 AM |
