Picture Freezing (GbSat)?Information exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 11-10-2002 Location: Hampshire, UK
I have a GbSat 2CI 0 receiver (H/W: 1.10, S/W: 1.46) and MM (1.03). I've tried both PetaCrypt 1.09 and Tetra 1.0 and I notice an occasional freezing of the picture. Is this a normal digital artefact with all receivers? Does anyone know if there is a more recent version of the receiver firmware that fixes this problem or indeed whether Pentacrypt 1.10 helps? Any input much appreciated. | ||
| Keep the faith, Shaun. | |||
| Specialist Contributor Join Date: 01-01-2000
| What is your signal strength and quality ? and what are you trying to recieve? what is your dish size and type of LNB ? it may also be due to poor or weak signal ?. Reagrds Old Satellite | ||
| | #3 | |||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Just in case it's not obvious, Shaun has also posted an MM thread because of concerns about the validity of his MM. This is what Nickolai said
| I should perhaps clarify that the freezes are just momentary, the channels are on Hispasat (e.g. Palco), the signal strength/quality is good and my dish is 80cm. Also, I see no such problems with the FTA Hispasat channels (such as Antena 3 or GTV). | ||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Sounds like a decryption problem Shaun, I get the same with the freecam occasionally. | ||
| | #6 | ||
| I don't know if I'm allowed to talk about specific files or not, but do different files (and file combinations) work better than others for the Hispasat satellite on the GbSat receiver? | ||
| freezing, gbsat, picture |
Similar Threads | ||||
| Freezing picture? | yazooo | Dreambox General | 3 | 24-01-2006 03:16 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| TSP Foot / Star - picture freezing? | markyd23 | Satellite PC Card Receivers & Internet by Satellite | 0 | 22-10-2005 07:02 PM |
| D.t.t Picture Freezing Prob's. | sat novice | Terrestrial Television, Digital and Analogue | 6 | 13-10-2004 01:13 AM |
| Sound / picture out of sync | Pict | Sky Digital (BSkyB) and Astra 28.2 East General | 4 | 21-07-2003 01:58 PM |
