Blindscan And 4.2.2 ReceiverInformation exchange on digital satellite systems other than Sky | |
| Specialist Contributor Join Date: 03-08-2004
Can anyone who knows well plse recommend for me a good receiver that can decode 4.2.2 transmission and can also carry out blind scan function. I know the fortecsatr 5100 ultra does blind scan but I am not sure if it can decode 4.2.2 transmissions. I presently use an interstar and it can't decode transmissions in 4.2.2. Plse help thanks, | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Don't know of a domestic STB that does both, but the Quali TV QS 1080R can apparently resolve 4:2:2 transmissions as well as being HDTV ready, although at £500 a throw it would be a lot cheaper to get a satellite PC card for the 4:2:2 stuff and the Fortec for blind scanning. Llew | ||
| | #3 | |||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | Most people here are more than happy with the SKystar2. Cheap'n'cheerful, does most of what you require. Check the PC Card section on this forum. Llew | ||
| | #5 | ||
| Member Join Date: 30-10-2004
| The Quali-TV QS-1080R Can Resolve 4:2:2 Transmissions With No Problems. You Can Scan FTA Or Scrambled Channel From A Pre Programmed Frequency List That You Can Edit. It Also Support's Diseqc 1.0 & 1.2. If You Get The QS-1080IRCI You Have A 1 CAM Slot. Chepest Place To Get The QS-1080IR Is From This Company In Spain. ANTNET Digital S.L. www.antnetdigital.com Tel: +34 91 81 633 80 Cost Me £400.00 Including The Euro1080 Viewing Card. So Not Include The View Card It Should Cost Around £300.00 | ||
| | #6 | ||
| Super Moderator Join Date: 01-06-2004 Location: Here again
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | You can set ProgDvb to blindscan an SS1/2 by writing your own transponder info for it, or the newer Technotrend drivers have a good scan function in them. L. | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | Tandberg Alteia are supposed to be good receivers, althoug being professional rx's are NOT cheap. They turn up on Ebay | ||
| | #8 | ||
My System: SS1. 3.4Ghz P4. 125cm Gibbi with Channelmaster feedhorn and Inverto C120 twin. 36v H to H 62E - 61W ![]() ...And thou were the truest friend to thy lover that ever bestrad horse..." | sprattgraham...... Could you put this in the 'For Sale' section as that is the correct place + You will probably pick up some interest ! Cheers L. | ||
| | #10 | ||
| Specialist Contributor Join Date: 07-08-2005 Location: west yorks, uk
My System: andrews dish - jaeger 1224 motor, vantage x221tsci, skystar 2, diablo v2.3, cyfra+ | | ||
| blindscan, receiver |
Similar Threads | ||||
| humax hd200 and 4.2.2 feeds | tapfit2004 | High Definition Receivers transmissions, satellite and Terrestrial | 14 | 25-08-2006 01:20 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
