Fortecstar. Ultimate problem/Ultra explanation
Information exchange on digital satellite systems other than Sky
Old 19-04-2005   #1
Mentally unstable.
Yorks's Avatar
My System: Pretend to know what I'm doing. Only the clever ones rumble me.
...Now he's joined a sat forum, And boy does he borem, When the hind legs off a donkey - he talks
Question Fortecstar. Ultimate problem/Ultra explanation
Hello Peeps,
I have recently bought and had installed a Fortecstar motorised system.
It would appear that there may be a problem with this model (or some of 'em),
relating to software. The receiver just sends the dish awol when you try changing channels on same satellite. Anyone else heard of this?
Anyway, in the meantime i have been given a Fortecstar Ultra which works fine, but i would be grateful if someone could help me with a few questions.
1).Which is the best way to scan in the channels. Satellite scan, Power scan, Transponder scan etc.
2).What do the different options do and when should i use them.
3). Is there any point in scanning ALL+D or should i just scan ALL?
Thanks,
Yorks
Ps. Not tps aswell.
Life's a bitch ................ and then there's S*y (No change there then)
Wurdoch ist ein Manker. (Mank being a city in the
Austrian Alpine foreland)
Yorks is offline   Reply With Quote
Old 19-04-2005   #2
Mad Scientist on loose
buzz's Avatar
My System: 10 dishes, 3 receivers.
Fortecstar Ultra
I would first bypass the positioner motor and hook up directly to the LNB. Have it aimed to a satellite then do a power scan with "all". This will take a little while but it does a complete sweep of the satellite and will find all possible transponders and what is on them. Before this is done though you need to make sure that the LNB info is entered correctly in the "antenna set up" part of the menu. If the positioner is irratic it may be due to how you set up the positioner information in the "antenna setup" part of the menu also. (I assuming this is a DiSecq controlled positioner motor)
buzz is offline   Reply With Quote
Old 19-04-2005   #3
Mentally unstable.
Yorks's Avatar
Yes,
It is a DiSecq motor. But the Ultimate doesn't seem to like it, whereas the Ultra does. The dealer/installer is trying to sort it.
Thanks for the advice on Power scan.
Yorks
explanation, fortecstar, problem or ultra, ultimate
[IMG] code is Off
Similar Threads
Anyone Using T-REX on Fortecstar? benbecula33 X-CAM, Ultra CAM, Dragon CAM, Diablo, T Rex 17 29-04-2006 11:29 PM
Fortecstar Ultimate twin tuner shakeeb Receiver software, international Section 0 29-04-2006 10:39 PM
Any PVR browser or Driver for FortecStar ULTIMATE ??? anil9898 Sky+ (Plus) and PVR Systems 7 02-12-2005 04:08 PM
Fortecstar Lifetime doesn't boot after uploadin new new boot and firmware jjab Receiver software, international Section 5 27-12-2004 10:53 AM
Ultimate v ? clab Cams and decoders General 1 14-02-2004 01:03 PM
