Echostar DSB 880 ProblemsInformation exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 19-07-2004
I have just bought an Echostar DSB 880 2Ci and have a small question. On the front panel there is a black perspex window that on most satellite receivers lights up with the channel N° etc. Mine remains blank although the receiver works well - but I can get all local BBC 1 channels except BBC1 West from Bristol - which I could get with my last two receivers (Nokia 9800s and a Strong) - can anyone help both with the channels and whether the panel should indicate something as I have had the receiver only since Saturday and if it should indicate something I'd like to change it - while I still have time. Thanks for your help Chief | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | If it shows nothing which I'm 99.9.% sure that it should, you should take it back. ![]() PS. have split your post from the other thread, as although it referred to the same receiver, the problem was not the same, hjave also moved into the correct section. | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Looked at BBC West and still there, it's on the same transponder as BBC South West, South and South East. | ||
| | #4 | |||
As far as the BBC channels - I'm gonna check to see if I have the above - from memory I don't think so but I know I have London; Midlands, East, North West and Yorkshire ... I'll get back to you. Cheers Chief | |||
| | #5 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Check that you have this transponder 10818 V, You can find the full list here http://www.lyngsat.com/28east.html | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Just looked at the Manual online and it isn't at all clear whether there is supposed to be anything other than signal and standby indicators on the front panel. | ||
| | #7 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | If you remove the lid, there would normally be a circuit board covering the back of the window which would hold the alphanumeric LEDS. This is the case with for example Aston Simba receivers, the 202 having a front panel display and 3x LED board, and the 201 having just the normal 3x LED board. Llew | ||
| | #8 | |||
Thanks Rolf - I can now pick up BBC West Chief | |||
| | #9 | |||
| Regular Member Join Date: 08-08-2004
steve (distributor) | |||
| | #10 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Thanks for clearing that up Steve, as you say it is confusing, as it looks like there should be a display. | ||
| | #11 | |||
Thanks again Chief | |||
| 880, dsb, echostar, problems |
Similar Threads | ||||
| Echostar DSB 2110 Problems, please help | azzguk | Receiver software, international Section | 15 | 18-11-2008 10:52 PM |
| echostar dsb 808 +funcard4 | dave32 | Cams and decoders General | 1 | 19-02-2004 12:36 PM |
| Few people seek help for sex problems | net1 | The Meeting Place | 0 | 22-08-2003 08:11 PM |
| EchoStar launches ninth satellite | net1 | Daily Satellite and Broadcast industry News | 0 | 08-08-2003 06:22 PM |
| diseqc motor & Echostar problems - HELP! | css_jay99 | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 25-06-2003 02:35 AM |
