Non-Sky FTA digital receiver Eurosport in English
Information exchange on digital satellite systems other than Sky
Old 01-06-2005   #1
My System: Sky+ Pace Prima Analogue
I was referred by another forum to this one to find out about getting a non-Sky digital satellite receiver to be able to get Eurosport in English after "patching". This is all very new to me, could anyone point me in the right direction?
cacofonix is offline   Reply With Quote
Old 01-06-2005   #2
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
Welcome...
Where are you located?
If it's the UK, then Eurosport have joined Top Up TV (TUTV) on freeview through your TV aerial.
You could buy a receiver and patch it but there is no guarantee how long this will last.
P.S. On Freeview the station, available on channel 49, will broadcast between 2pm and 11pm daily
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 01-06-2005   #3
Site administrator
Analoguesat's Avatar
Ah - another DS refugee joins our merry band. Welcome !
There are assorted Eurosport transmissions in digital, although not all of them carry all the languages.
First a question - have you got your Pace Prima connected & working yet on the 19E analogue transmission? That should be your first priority as you are desperate for this service.
Old 02-06-2005   #4
No I have not got it connected yet, I'm awaiting the release of the Inverto, then I can ditch my Sky+ box - anyone want it, one careful owner? - and then I'll use the minidish and cabling for the analogue setup...although talk of the Topfield having the capability of allowing TUTV makes it seems tempting also...by the way, should I get a satellite finder gauge thingy to move the dish from 28.2 to 19.2E?
Old 02-06-2005   #5
My System: echostar 808 2CI Matrix Reloaded Cam Fixed dish 13E
I'm not an expert in reorientating dishes but most of the satellite finders are more trouble than they are worth. Capturing analogue signals is quite easy as they show almost immediately (on the TV) whilst with digital signals you have to wait for the receiver to respond to the signal.
eghamhigh is offline   Reply With Quote
Old 02-06-2005   #6
rolfw's Avatar
Real name: Rolf
I have to disagree there, whilst not essential, even cheap finders can speed up the process considerably and can be very good for fine tuning.
Rolf
Old 02-06-2005   #7
Whilst I realise I have to move the satellite dish thru 9 degrees from 28.2E to 19.2E, do I have to adjust the dish in the vertical plane at all...I live in SE London?
Old 04-06-2005   #8
mike1's Avatar
My System: Dreambox / Motorised 88cm
yes 31 degress for the elevation.
If you behind the dish you would be moving it towards the right to astra1.
mike1 is offline   Reply With Quote
Old 06-06-2005   #9
Sorry, is it that for Astra 1, 31 degrees of elevation is required? If so what is the current elevation for my Sky digital Astra 2E dish setting?
Old 06-06-2005   #10
rolfw's Avatar
Real name: Rolf
For SE London, Astra2 would be approximately 25 degrees and Astra1 would be 28, there will be about three degrees difference, with Astra1 being the higher of the two.
Rolf
Old 06-06-2005   #11
Ding Dang Doo
gameboy's Avatar
Mark the present position of the dish on the pole and the angle on the dish bracket.
I don't think you will have to change the dish angle by much.
Try just slackening the pole bolts and moving it to the right with the receiver tuned into a FTA channel on Astra 19.2'E.
You should get a signal. Pause a few seconds after each movement as the digital signal takes a second or two to clear.
Once you have a signal tighten the pole bolts.
You could then try the same with the dish angle bolts to see if the signal gets stronger.
If you have no luck you have the markings to get back Astra 28.2'E without problems.
Old 06-06-2005   #12
thanks for this, seems like I should have no problem, ICBIJST!
digital, english, eurosport, fta, nonsky, receiver
[IMG] code is Off
Similar Threads
Satellite news April Satdude Transponders & channels 2 27-04-2004 09:26 PM
Transponder update 20/10/03 Satdude Transponders & channels 0 20-10-2003 04:52 PM
Transponder update 13/10/03 Satdude Transponders & channels 0 13-10-2003 10:40 PM
Transponder update 15/09/03 Satdude Transponders & channels 0 15-09-2003 09:51 PM
Transponder update 24/07/03 Satdude Transponders & channels 0 24-07-2003 09:16 PM
