2 Receivers via 1 Dish/LNBInformation exchange on digital satellite systems other than Sky | |
| Dreaming Satellites Join Date: 12-06-2005 Location: Stockton-on-Tees, Cleveland
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, |
Is it possible to hook up 2 receivers to 1 LNB (via loop through connection)?? I have a Technomate TM-1000 D Digital Satellite Receiver with a loop through connection underneath the LNB connection and I have a Comaq Digital Satellite Receiver | ||
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver, | What are the advantages and dis-advantages of doing it through the loop through way? | ||
| | #4 | |||
| Regular Member Join Date: 05-01-2005
So if you tune a channel which is Horizontal and Lo, you cannot tune a channel which is Vertical and Lo for example on your second box. I think you would get very disappointed quickly as the choice of channel on the Technomate would affect what you could receive on your second dish. Provided you are a competent DIY-er, you would need a Dual output LNB (this is basically a single LNB, but with two seperate antennas internally), you connect your existing cable to one output and run a new cable to the second output and box. Costs depends on how fancy a LNB you want, but around £30 is probably not too far out of the ball park | |||
| dish or lnb, receivers |
Similar Threads | ||||
| New software upgrade for Thomson/Grundig receivers - 3/07/03 | net1 | Receiver software, international Section | 6 | 08-06-2007 06:18 PM |
| Very old dial tuning analogue receivers - any value? | Rob Wheeler | Analogue systems | 15 | 23-04-2006 10:33 PM |
| pls rank the top 10 digital receivers | krassi22 | Digital systems | 8 | 21-08-2005 01:49 PM |
| Website for Force receivers ? | Rob | Receiver software, international Section | 2 | 14-01-2004 08:25 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
