SKY Digital Card in Technomate receivers
Information exchange on digital satellite systems other than Sky
Old 19-06-2005   #1
Dreaming Satellites
My System: Dreambox 8000 HD, 80cm Orbital Satellite Dish Motorized LNB with 2 outputs, 2nd output leading to upstairs and using Dreambox 500S. Pioneer VSX-1018AH-K Amp/Receiver,
I was just wondering if u can use a SKY subscription card in the Technomate receivers ( the 1s with the cams, slots - obviously)?? if so.. can u still use a motor for the other satellites?
Cheers,
Marc
marcaaron20 is offline   Reply With Quote
Old 20-06-2005   #2
Amo Amas Amant Admin
Topper's Avatar
Question You can insert it
But it will not do anything to decode the subscription channels. What exactly are you trying to achieve?
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 20-06-2005   #3
john_graydon's Avatar
My System: Dusty Dreambox 7000s, & Sky HD.
Cheers,
Marc
I suppose it would work with a dragon cam inserted into the CI slot and then the card inserted into the cam. But you need to programme it before you could use it with the card id number.
Happy Dreaming
john_graydon is offline   Reply With Quote
Old 02-07-2005   #4
My System: Pace Sky+ V2 160GB, TM5500DAPCI + various cams, several dishes
Technomate & Dragon & Sky Card
Sky+ card working in (almost) latest s/w working in Dragon 2.06 in my Technomate TM5500DAPCI - and it still allows access to the other satellites/encryptions for which the receiver/cam set-up works without the card. Allows access only to those channels for which the card is subscribed.
Rather slower to change channels than the Pace 3100 Sky+ box, and the channel list is not anywhere as informative as that shown on the Sky+ EPG - just a list of channels in numeric or alphabetical order, and little discrimination in the channel names (e.g. does not show "Sky Cinema 1" and "Sky Cinema 2" - just "Sky Cinema" twice on two successive channels).
To get it to work, you have to load the s/w into the cam, and then enter the Sky RECEIVER serial number (which you find in the Sky receiver Set-up menus) - NOT the Viewing Card Number - from the paired receiver into the cam. Then switch the receiver to Standby and back on again.
John A
jeallen01 is offline   Reply With Quote
Old 12-07-2005   #5
My System: 1.2Cm dish, Motorized, TM1500CI+,dragon cam,SS2....
John A
hi,
I am now using TM1500+, dragon cam and sky card, it works fine.
I got Sky Cinema 1 and 2 on the list, its been a while, but something still confused.
do i have to use the dragon cam?(except sky that cam is really useless.. does matrix or some other cam working on this case?)
do i have to put the card back into sky box(to update the sky card?)
coloureye is offline   Reply With Quote
Old 21-07-2005   #6
My System: Sky Digibox, Technomate 5500, Humax CR-5510 and Comag Porty 2 Dragon CAM 45/80cm mesh dishes, 35cm solid dish, Triax TD110
At the moment, the Dragon CAM is the only CAM that will allow use of the sky card with it.
From what I have read in vaerious places, you do need to re-insert the sky card into a Sky Box in order for it to update - but I haven't tried my Sky card in my Dragon CAM, so I can't say for sure.
MattJ is offline   Reply With Quote
Old 22-07-2005   #7
thanks for the infor.
regards
Coloureye
Old 24-07-2005   #8
D4ftpunk's Avatar
My System: Dreambox 7020 Dreambox DM500 Sky Thomsom Digibox StrongSat FTA Reciever 80cm Dish + 45cm Dish via Disecq A/B.
if you use a cam emu such as newcamd you dont have to ever take sky card out of the box, Im using cardserver0961 (from newcamd) and cs2gbox/gbox to view my sky card. Ive had it like that for a few months, and ive checked the update dates. But these have past 3 times now and the card is still wroking 100%, you just have to set EMM to yes
give me money now
D4ftpunk is offline   Reply With Quote
card, digital, receivers, sky, technomate
[IMG] code is Off
Similar Threads
Transponder update October 2007 Satdude Transponders & channels 666 25-10-2007 11:44 PM
Sky's reponse to FTA cards. net1 Sky Digital (BSkyB) and Astra 28.2 East General 21 23-12-2004 02:09 PM
Sky unveils plans for Plus net1 Sky+ (Plus) and PVR Systems 0 03-03-2004 08:24 PM
digital terrestrial ariel into sky box slicer Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech 16 27-01-2004 01:03 AM
BBC accused of £500m digital spend net1 Terrestrial Television, Digital and Analogue 0 16-07-2003 07:41 PM
