System Options! Good Choice??Information exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 20-06-2005 Location: Scotland M8 Corridor
My System: Kaon KSC 570H PVR, Triax TD88 REX Single 0.3db LNB, SM3D12 DiseqC Motor, Digifusion FVRT100 Freeview Dual PVR, Cambridge Audio DVD57, Sony STR-DB930, Mirage AVS-500/ FRX-S8, Toshiba 36ZP18P. | Analoguesat and Toppervte33h. Thanks for the info. Been doing some surfing &..... I think I have decided on a System but would like a technical opinion. I would like the system to be as easy to operate as possible mostly so my Fiancee can use it and second as I am new to this. I would like to have got a DB and TD but cannot justify the cost just now vs. functions for a beginner. Creative Satelitte UK ( h**p://www.creativesatellite.co.uk ) appear to have a good price on The Fortec Star Ultimate @ £170 plus vat which I beleive is easy to patch and Fortec Star have good reviews. This appears to offer all I want for now including PVR, EPG, Blind Search, etc so I can record up to 2 programs as long as they are on the same satellite (I guess). I am a Home Cinema nut but not really sure of the picture and sound quality. I currently have a Fusion FVRT100 Freeview PVR and up to now quite impressed. They also have 80cm Dish + Wall Mount Moteck Digipower SG 2100 DiseqC 1.2 Motor Fortec Star 0.4 dB Digital Universal LNB 10mt Full Installation Kit for £97 plus vat and I was going to upgrade the LMB to MTI Blue 0.3bd or Unifit 0.3db (£10). Will this be suitable for most of the Romanian Channels (not worried about atmos) and other FTA? The only think I am not sure of is if this Motor will give me support for USALS? Would this be a better option with the blind search options of this receiver? What do you think for £320 plus delivery this appears good value and should keep me quiet for a while. Please remember I am a complete novice but like reseaching on the web but may have got it all wrong! Thanks in advance. Al Pal. | ||
| choice, good, options |
Similar Threads | ||||
| The good, bad and ugly. | arsen | Wavey's Jokes Corner (May contain nuts) | 0 | 06-07-2006 03:28 PM |
| HDTV Primer | spiney | High Definition Receivers transmissions, satellite and Terrestrial | 0 | 16-01-2006 12:42 PM |
| Lists of Software upgrade sites | jo_lb2002 | Receiver software, international Section | 17 | 23-11-2004 08:05 PM |
| how good is jonsa 4.2m sat dish | mjs1006 | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 6 | 24-09-2003 11:30 AM |
| Hello All good people here | >COR< | The Meeting Place | 4 | 14-09-2003 02:10 AM |
