Loss of Signal ProblemInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 05-03-2003
| I am also having the same problems with loss of signal. I have an echostar 3000ip via with aston 1.05. I connected my sky minidish to the receiver and managed to get a few shopping and travel channels. I wanted to test voltage and resistance readings at the lnb end but have no idea how to do this. I really would like to get the bottom of this before I pay somebody to change lnb or realign my dish. Thanks for all advice so far nad | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Unfortunately being able to test the voltage at the LNB end of the cable will only tell you whether the cable and connectors are good. You will still not know whether it is alignment or the LNB. What you can do, is have someone watching the signal strength on the receiver when it is showing nothing and put your hand over the LNB, this should give you a small level reading, try it on both polarities. You can test the voltage with a 24 volt light bulb, and rather than get someone in to change the LNB, why not buy one yourself, they are a doddle to replace, just make sure that you have some self amalgamating tape to seal the F connector. Is the dish motorised? | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | No Nad, it is no more difficult to replace the LNb, but there are more things that can potentially be causing the problem. As with Tirosh's problem, although it didn't at first logicallyappear to be so, it was in fact the dish alignment. | ||
| loss, problem, signal |
Similar Threads | ||||
| Temporary loss of signal problem... | yazooo | Dreambox General | 57 | 13-12-2005 12:57 PM |
| Digital Terrestrial (Freeview) TV reception, Aerials! | spiney | Members' input on FAQ and How To's | 0 | 09-06-2005 03:05 PM |
| Transponder signal loss | mreyelid | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 0 | 23-01-2004 11:28 PM |
| Skystar 2 Signal 50%, quality 50% - but no real signal | zoltiz | Satellite PC Card Receivers & Internet by Satellite | 4 | 21-12-2003 08:17 PM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
