My Lidli reciever has frozen?Information exchange on digital satellite systems other than Sky | |
| Member Join Date: 30-06-2005 Location: Pembrokeshire, UK
My System: Lidli Comag party 11 system. | Hi I'm looking for some advice. i recently purchase one of the Lidi Comag systems due to the fact that I think the German anlouge signal is also going to be switched off next year. I smiple connected the new LNB to the existing anoluge dish and there it was? Astra 1 with all the german channels. I then noticed that the reciever would accomodate more than just the one signal so I ordered two more LNB a bracket and a 4 way switch and to my suprise I could pick up Astra 1, Astra 2 and Hotbird. That was until last night when the reciever just froze on one channel with no picture. I turned the reciever off and on again but to no avail. I then left it off for some time then turned it back on where it can up with 'load' on the display? Has the reciever reset itself? and is downloading the software again? I left it for about an hour with no change. Does anybody now if there is a keying in sequence on the reciever to set it back to the default settings?? Or am I being to keen in setting it up with three LNBs?? Any help would be most apericiated Cheers! | ||
| | #2 | |||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue |
| | #3 | |||
| 'What's On' Guru Real name: Chris Join Date: 25-06-2005 Location: High Wycombe, Nr London, UK
My System: 1m Orbital Motorised Dish, Fixed 65cm Fortec Dish on Astra 1, Fixed 45cm Minidish on Hotbird, Pace MSS500, TM-5600D CI USB Super, Nokia 9800s, Skystar USB 2, Grundig Sky Digibox, Manhattan Plaza XT-M ![]() Best newbie geek pit /age ratio 2005 |
On another note, I assume somehow the three LNB's could be confusing the reciever...maybe this is a bit obvious, but have you tried it with just one LNB directly connected to it? | |||
| | #4 | |||
Problem solved? I diconnected the output from the 4 way switch turned the reciever back on and the display came back with weak signal and I was able to change channels. So reconnected the reciever to the 4 way switch and everything is back to normal. I then went through the channels on Hotbird and it froze agian on the same channel 0390? 189? EBS? Has anyone else had this problem?? Thats for the comments and help. Cheers! | |||
| | #5 | |||
| | #6 | ||
| Regular Member Join Date: 27-11-2004 Location: S. Lanarkshire
My System: Sky Digital - Freeview - FTA Digital Satellite (19E) - Broadband | My box (which I assume is the same) crashes even before reaching EBS, just the transponder it is on. When I scanned, it froze and shut down. So I deleted the whole transponder from the list, then everything was fine. But now I'm back at 19.2E, and it sure feels like home ![]() I'm now waiting patiently for Domino Day on RTL II in November. | ||
| | #7 | ||
Blog Entries: 1 My System: Sky UK. FTA analogue & digital satellite from 6 fixed dishes (5E/7E/9E/10E/13E/16E/ 19E/23E/28E) Pace MSS100, Echostar IP3000VA, Technomate TM-1000D, Dreambox 7020S ![]() The last noble sat warrior to fly the olden flag of Analogue | If you want to have a look at EBS, just put the tp back manually 12476 H 27500 3/4 and set the channel up with VPID 101 APID 202 for English. Then add in XStream V551 A552 Mesopotamia V701 A702 2M Maroc V601 A 602 | ||
| | #8 | ||
My System: Sky Digital - Freeview - FTA Digital Satellite (19E) - Broadband | Box crashed before getting near it! I'm back at 19E, which seems to have gotten much smuttier in the last few months. | ||
| frozen, lidli, reciever |
Similar Threads | ||||
| Need Upgrade "Pace DVR 500 digital integrated reciever decoder" | logger17 | Receiver software, international Section | 3 | 01-04-2005 07:01 PM |
| reciever thechnostar 9900 P | remoram25 | Receiver software, international Section | 0 | 07-03-2004 04:27 AM |
| Help, fun card not working in strongsat reciever | jacklee66 | Cams and decoders General | 5 | 11-02-2004 04:19 PM |
| Reciever compatability | johnd231159 | Magic Module | 0 | 29-08-2003 11:36 PM |
| Reciever For Cyprus. | koolclub | Digital systems | 0 | 11-07-2003 05:31 PM |
