Choosing a receiverInformation exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 18-06-2005
My System: satellite |
I am indecisive about the purchase of the receiver. I believe that one of these 3 will be a good choice, but which is the best? Could you help me choose? Kaon 570, MVision E+ FCIS7000 or Dreambox DM500? Thank you very much! Best regards, Red | ||
| Super Moderator Join Date: 08-03-2005 Location: J6 M5
Blog Entries: 1 My System: DM7020S ~ DM500s ~ sg2100 ~ Gemini ![]() If he were not a wizard, from head down to the root, you would have got to worry-your DB only boots | I cannot comment on the Kaon or MV but I have a DM500s. The learning curve to set it up was quite steep (but that was more because I didn't set the dish up correctly) and being good with a PC helps. There is plenty of support for Dreamboxes (inc key$) especially this forum - have a look at the DReambox forum.The "best" depends on you- if you want a box that works out of the box then the DB might not be for you but if you are technically competent, enjoy a challenge and keen, give the DB a try. Good Luck! | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hi Rred A good reply from mhku. I think you need to set out what it is you want to achieve from a receiver and then decide which one would fit the bill. I'm sure there will be others which you may have not considered but would be suitable. Let us know. | ||
| choosing, receiver |
Similar Threads | ||||
| 2 dishes: Add 2nd receiver, UHF TV and FM | Artist 2004 | Multi-receiver/TV systems - Domestic only | 8 | 11-03-2007 09:14 PM |
| Samsung dead. PLZ HELP!!! | Zebo | Receiver software, international Section | 9 | 16-02-2006 12:05 AM |
| Matrix Reloaded How To by AHAC | rolfw | Matrix Reloaded, Revolutions and CAS interface | 52 | 27-12-2005 12:02 PM |
| receiver query Eutelsat Hotbird | dcjag | Digital systems | 3 | 03-10-2003 03:48 PM |
| IFA 2003 Berlin exhibition report | net1 | Digital systems | 0 | 01-10-2003 08:02 PM |
