How to get Max TV on Sirius 2 at 4.8°E?Information exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 20-06-2005 Location: Scotland M8 Corridor
My System: Kaon KSC 570H PVR, Triax TD88 REX Single 0.3db LNB, SM3D12 DiseqC Motor, Digifusion FVRT100 Freeview Dual PVR, Cambridge Audio DVD57, Sony STR-DB930, Mirage AVS-500/ FRX-S8, Toshiba 36ZP18P. |
Now I have my system installed and working I can now see that there are a lot of Romanian Channels available with very good signal on Max TV on Sirius 2 at 4.8°E. Although they were clear for a while they are now encoded on Viaccess 2.5 which I believe has not been compromised yet? I can get hold of a card directly from Romania (and its very cheap per month! ) but would I be able to use it with a Viaccess CAM, I have seen on here that some of the services require a special receiver?If it would be possible to just add a CAM with a Max TV card which CAM would be best? I was considering a Dragon 4.1 anyway would this be suitable? Thanks in advance. Al Pal | ||
My System: Kaon KSC 570H PVR, Triax TD88 REX Single 0.3db LNB, SM3D12 DiseqC Motor, Digifusion FVRT100 Freeview Dual PVR, Cambridge Audio DVD57, Sony STR-DB930, Mirage AVS-500/ FRX-S8, Toshiba 36ZP18P. | Thx Burnham Beach but I do not have an embedded cam so I will need to buy something and was wondering if the Dragon 4.1 would be a good choice. DOes not appear that much more expensive than a Viaccess Cam and gives me a lot more!? I have seen there have been some issues using a Dragon and my Kaon.... | ||
| | #5 | ||
My System: Kaon KSC 570H PVR, Triax TD88 REX Single 0.3db LNB, SM3D12 DiseqC Motor, Digifusion FVRT100 Freeview Dual PVR, Cambridge Audio DVD57, Sony STR-DB930, Mirage AVS-500/ FRX-S8, Toshiba 36ZP18P. | I have the oportunity to get a hand me down Viaccess Red version 4.84 for £10. Would this be suitable for using with my Max Tv viewing card and would I have any compatability issues with my Kaon 570H? Max TV told me to check www.viaccess.com for compatable recievers where they do mention Red Label Eurocam is this the same thing? My friend claims it will be ok and do a lot more but I wanted to check here first.... Thanks in advance.... | ||
| 48°e, max, sirius |
Similar Threads | ||||
| max g-890 | ashraf_donia | Receiver software, international Section | 11 | 17-08-2008 10:20 PM |
| Transponder update October 2007 | Satdude | Transponders & channels | 666 | 25-10-2007 11:44 PM |
| Sirius seeks place for satellite radio in iPods | gameboy | Daily Satellite and Broadcast industry News | 0 | 10-02-2005 09:47 PM |
| Sirius 4 ordered | Analoguesat | Daily Satellite and Broadcast industry News | 0 | 13-01-2005 06:34 PM |
| Sirius 2 (4.8°E) missing channel...pls help | ardelos | Receiver software, international Section | 2 | 07-01-2005 02:17 AM |
