Manhattan boot problemInformation exchange on digital satellite systems other than Sky | |
| Member Join Date: 02-05-2005
My System: Motorised Starlight 6800 |
My Starlight 6800 has just developed the infamous boot problem. Looking on various forums ive seen that some people have sent the reciever back up to 4 times trying to fix it. I'm wondering, who pays for the carriage of the reciever? As this is a known problem, do Manhattan/Eurosat foot the bill each time? Also, is there someone specifically at Manhattan i need to contact for this? Ive had reciever since November 2002 & its been fantastic up till now. | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Have you tried emailing Support on the Manhattan website. If so, what did they say? http://www.manhattan-receivers.com/modules/news/ | ||
| | #3 | |||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | When they say 'needed' do they mean they have yet to write the update? | ||
| | #5 | ||
| The memory issue is soft/firmware issues, usually due to a lazy designer. It can be fixed with an upgrade. The boot problem is hardware related, down to the Eurosat partner in Korea using substandard chipsets in the receivers. Its well documented and short of a new motherboard, is terminal for the receiver. In this situation the receiver would have had to go back to a repair shop, fixing under warranty is probably the only option for the supplier as it is effectively a manufacturing defect (in other products you would have a 'recall'). The carriage however is at the discretion of the supplier, most would be satisfied with carriage borne on each way by the sender. But if the delay in repair/replacement becomes unacceptable to the original owner , especially before sending, then it would seem reasonable to use a bit of persuasion to get the unit collected /returned at no cost. Think of it this way, would you have bought the receiver if you had an inkling of the problems that might lie ahead, and be willing to foot half of the transit bill(s)? | ||
| There is a very fine line between "hobby" and "mental illness" | |||
| | #6 | ||||
Maybe i'll just have to count my losses & get new reciever. The machine was fantastic except for the boot problem so maybe i'd like a Plaza ST 550. Are there any similar design faults with this (& other latest) models ? Thanks for the replies guys. | ||||
| | #7 | |||
| boot, manhattan, problem |
Similar Threads | ||||
| Manhattan Starlight 6900/STB Editor Problem | inabsentia | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 12-10-2005 02:23 AM |
| Have a problem MPEG2 DVD conversion | mgharbawy | Computer Discussion | 4 | 21-06-2004 10:02 PM |
| hi! i have Manhattan 5900+... big problem!!!! | uunoplus | Cams and decoders General | 4 | 03-01-2004 11:50 PM |
| Problem with Manhattan DSR2500APCI | zarf99 | Digital systems | 6 | 19-09-2003 01:47 AM |
| is this a diseqc problem | doggy | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 14 | 05-09-2003 02:44 AM |
