Which Satellite to choose?Information exchange on digital satellite systems other than Sky | |
| Member Join Date: 20-04-2003
I am about to buy a fixed dish system, as motorized is out of the question at the moment. I have a Skystar 2 card. Would I get more channels that can be encrypted viewing 13e/19e or just pointing at 1w or 30w. Originally I was going to get a twin LMB to view 13e/19e, but it seems that alot of the encrypted channels cannot be decoded with the Skystar 2. So I was going to just get a single fixed dish pointing at 1w only. But, I hear that Conax may be changing. What would you do? Coops p.s. I am buying at 88cm dish, I cannot go any bigger. Does this rule out the West sats. I am in South East of UK. Looking to view football. Thanks | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Go for 1 West Coops, the worst that can happen is that you have to move it. You should be able to pick up some football with the 88cm. | ||
| Would I be able to buy: 88cm Triax dish, Triax 6 degree bracket, Two Fortec Star 0.5dB LNBs. 2 way Diseqc switch & Triax wall mounta 2 lmb system (Designed for use with Hotbird and Astra) and set it up on 1w and 5w to view Canal + fr which is encrypted using SECAM (and/or?) Nagravision? Coops | ||
| | #5 | ||
| Regular Member Join Date: 27-03-2003
yes i used a setup some time ago with a 1mtr lenson heath dish and a offset bracket, i fixed the dish on 1degree west and used a second in those days a telecom lnb on the bracket, in the end i motorized the lenson dish to receive more satellites which is neater then having a additional dish also on astra. | ||
| | #6 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | @ Coops, the Canal+ channel on that satellite is in analogue, SECAM is a transmission standard for analogue signals, like PAL I is in the UK. It would also be in black and white only, unless you have a SECAM compatible TV. | ||
| | #7 | ||
| ahh, I see. I'll forget 5w then. I've had a look at football sites and compiled a list of channels that show some premiership football on 19e/13e/1w. I only included channels that can currently be decoded using the Skystar. Canal+ Denmark 1 West Conax Canal+ Finland 1 West Conax Canal+ Bla 1 West Conax Canal+ Norway 1 West Conax Canal+ Sweden 1 West Conax Canal+ ZAP 1 West Conax NRK1 1 West Conax TV2 Norway 1 West Conax TV4 Plus (Sweden) 1 West Conax BKTV Sat 13 East FTA Canal Algerie 13 East FTA Canal+ France 13 East Seca 2 / Viaccess Canal+ Rood 13 East Irdeto / Seca ARD Das Erste 13 East FTA Polsat 1 13 East FTA C5 (Canale 5) 13 East FTA DSF 13 East FTA RTL 13 East FTA Premiere Sport CL2 13 East Betacrypt ORF1 13 East Irdeto Canal+ Blauw 13 East Irdeto / Seca NED2 13 East Irdeto / Seca RTL5 13 East Irdeto / Seca SBS6 13 East Irdeto / Seca Polsat Sport 13 East Nagravision Eurosport 13 East PAL Canal+ Vert 13 East Seca 2 / Viaccess TF1 13 East TPS Crypt HRT-TV3 13 East Viaccess SF2 13 East Viaccess SLO-TV2 13 East Viaccess RTPi 19 East FTA Sport+ 19 East Seca 2 / Viaccess Obviously the Canal+ package on West1 looks tempting, but I will be gutted if they change it from Conax(anyone know when we will know?) I'll be screwed. So if If I buy a 2 LMB system and set it up to see west1 on the first LMB and just leave the second LMB up there basically doing nothing. Is it easy enough to move the dish to receive 19e and 13e on the second LMB? I am not installing this as I'm crap at this type of thing. I just want to make it nice and easy on myself when the installers have gone if I have to change it. If I bought an angle and sat meter I should be able to acheive this? I guess what I am asking is that if the dish is set up to see West1 does that mean I will be able to see the east sats from where the dish is physically fixed? Finally, one last stupid question, on the list above it says for example that Canal+fr on 13e is encrypted using Seca 2/Viaccess. Does this mean it is being encrypted in both or as long as I can encrypt one of them I will be okay? Thanks for taking the time to read this, I just want to get this right before I take the plunge. Cheers Coops | ||
| | #8 | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Depending on which LNB mount they use, you might be able to pull in both 1W and 13E using a DiseqC switch, that would at least give you some flexibility if 1W changes encryption. In the south and the Midlands, I can get 1 West with a 63 cm dish so you should have a good chance of getting both. If any channels are listed in simulcrypt with Viaccess, then you should be able to receive them, but for how long is another matter. | ||
| | #9 | ||
| An Update: I finally received my system and the installer was due round today. He didn't end up installing the dish because he thought I had ordered a monoblock system rather than a flexi block system. He said this meant it would take too long to install today(I hadn't looked at the instructions for the block at this point, I had a look after he went and it was very very simple, even I could do it). He also said that the Diseqc switch was not waterproof and so if he installed it and it then got wet, it would (in his words)"Be my fault and not his" So, I phoned another installer, explained the situation and he sounds a lot more savvy. He is coming tomorrow. One other thing the original guy said was(and this leads to my question) was that the wall I wanted it on(east) is no good. I would need it mounted on the south wall. This is the bit I need to check. I'm not that confident that original guy knew what he was talking about. So the system I have is at : http://www.satellitesuperstore.com/fixed-dishes.htm It comes with a triax wall mount(about a third of the way down the page). From the picture it looks like it could be mounted on an east wall to face south. I already have a sky dish on the east wall that is pointed at around 2.00 o'clock if you are looking at it from behind the dish(If that makes any sense!) My question(finally) is do you think I could get the dish fitted on this wall. I know it's a difficult question to answer without seeing it but, if you look at the sky dish it looks as though it could easily be moved 15 degrees west to point at Hotbird from it's current position. The problem I have is that it can't be mounted on the south(ish) wall as it will be too exposed to vandalism. Cheers Coop | ||
| | #10 | ||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | Hi Coops Yep 2.00 O'clock makes sense. I suppose the point is, on a true easterly wall you should be able to pick up any signals east of south but the wall would be in the way for anything west of south. Unless of course it's at the top and the lnb has a clear sight of anything westerly. | ||
| choose, satellite |
Similar Threads | ||||
| R.R. Satellite Communications Ltd with Viaccess | net1 | Daily Satellite and Broadcast industry News | 2 | 13-03-2009 01:56 AM |
| Digital satellite viewers lose free channels | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 5 | 16-06-2005 01:22 PM |
| Last-minute deal on free-to-air satellite | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 11 | 29-10-2003 11:29 PM |
| EchoStar launches ninth satellite | net1 | Daily Satellite and Broadcast industry News | 0 | 08-08-2003 06:22 PM |
| Will the BBC's satellite dream ever take off? | net1 | Daily Satellite and Broadcast industry News | 0 | 26-06-2003 08:49 PM |
