Help to choose
Thread Tools Display Modes
Old 04-09-2005   #1
My System: TEchnomate 1500 CI+ Super 80cm Dish Fortec Start Universal Single 0.3 NF
Question Help to choose
Hi every one,
As I live abroad I am thinking to buy a satellite system, but I see that is much more complicate that I thought. I don’t understand nothing about satellite, I would appreciate very much some help.
What I want is this; right now I just want watch free channels, particularly from Brazil and Spain. I am living now in Scotland but in a short while I will move to south of Europe so I will take the satellite system with me, I don’t know if this detail is important. Quality of image and sound is important but I don’t want to spend too much money in the systems.
So now the questions; what receiver? What size of dish? Do I need anything else?
I have seen very good reviews about Technomate TM-1500, but perhaps this is too much for what I need.
regards
burnet01 is offline   Reply With Quote
Old 04-09-2005   #2
why not wait till you settle in your new place and buy a system there.it will probably work out cheaper and it will also give you plenty of time to do some more research.a good starter set i would recommend is -any of the plaza boxes from manhattan,triax88cm dish,and possibly the stab100 motor.that should meet all your wants,and wont dent your pocket too hard.
TWAG
twag42 is offline   Reply With Quote
Old 04-09-2005   #3
the same system will not work in other country?
TWAG
Old 04-09-2005   #4
Amo Amas Amant Admin
Topper's Avatar
Smile Well
That really depends on what you intend watching. The signal strengths of satellites vary enormously when you start moving about Europe as footprints are different for each transponder on each different satellite. Thus if you buy an 80cm dish in Scotland and watch certain channels there when you move to Spain the reception may be decreased, alternatively the reception may be improved. It is all down to the footprints of what you want to receive and watch. In Spain I understand they have a good DTH system so that your satellite system may not be required out there and you may not have line of site to the satellite you want to watch from a new location. twag42 is just trying to make you aware that it is even more complicated than you think and he doesn't want you to waste money.
__________________
Formerly toppervte33h
Show Your Support
by clicking the button
Thank you.
Freddie Flintoff is back
Old 04-09-2005   #5
I apreciate guys, where I live there is not any shop where i could go and talk with the salesman and find out everyhting, this is the only place I found to clear all my doubts.
In response to your quote "That really depends on what you intend watching" I just want to watch free channels from Brazil and Spain.
I understand the signal strenth vary depending of the location, I was wondering wich size of dish could work fine here in Scotland and in the south of Europe, perhaps 80 cm, 1m.
And what about the receiver? any sugestion?
Old 04-09-2005   #6
Topper's Avatar
Smile Choices choices
If I had the dosh at the mo I would buy the technomate ci 1500. There are many threads about it there is even a sticky I think with a full assessment. Do a search for it, the advantage of this is that it is an FTA receiver that someone is producing a patch for which will decrypt some extra channels click here for some info. I would need to know what channels you wish to find so have a look here to see which Spanish channels you can get FTA on Hispasat 30W are these enough for you?
__________________
Show Your Support
Thank you.
Old 06-09-2005   #7
Toppervte33h, thanks again for your help.
The few channels I wish to watch are in Hispasat 1C (30 W) and they are FTA.
Also I wish couple of channels from Brasilsat B1 (70 W); Rede Globo and SBT Rede which I believe are FTA as well; as www.lynsat.com said.
Once I know the channel and the satellite coordinates I wish to watch, how do you know what size of dish is need?
I am interested in channels from 2 differents satellites. As each satellite got a different coordinates, then I wont be able to watch channels from both satellite ate the same time, is that right?
Do you think it’s worth buy Technomate 1500 patched from Ebay or from the shop with out patch.
Old 06-09-2005   #8
Topper's Avatar
Smile Ermm no
No problem
Not possible it is below the horizon from Scotland and Spain
If you could see both sats and they were 6 degrees apart you could use one dish and a monobloc LNB which will receive 2 sats simultaneously. But as one of your options is no longer an option I do not know what to suggest
Depends how technically minded you are, whichever you choose you will have to learn how to patch if you want more channels but buying already patched will show you can receive and what you need to maintain
__________________
Show Your Support
Thank you.
Old 06-09-2005   #9
Hi toppervte33h
so, it is not posible to receive the satellite Brasilsat from here Scotland,
is there any way to receive that satellite, Brasilsat? as is the one i am most interested in the channels from Brazil
Regards
[quote=toppervte33h]No problem
Old 06-09-2005   #10
Mod and septic resident
Channel Hopper's Avatar
There is a Brazilian channel on Astra 28East (or at least there was a couple of months ago). You may also find programme content from South America on Hotbird 13 East, but probably not dedicated to one particular country.
Brasilsat is not available from the UK.
__________________
[IMG] code is Off
Forum Jump
Similar Threads
Which would you choose? kleefarr Wavey's Jokes Corner (May contain nuts) 1 10-04-2005 05:50 AM
Have a doubt which card to choose d_lamer2003 Satellite PC Card Systems & Internet by Satellite 20 20-03-2005 04:57 PM
Need your help to choose my HDD for DM7000S kim1406 Dreambox General 10 03-01-2005 07:14 AM
Sky Choose Thomson for New Sky+ gameboy Sky+ and PVR Systems 0 28-09-2004 06:27 PM
Which Satellite to choose? coops Digital systems 12 10-05-2003 08:54 PM
