Humax 5400 reverting to one channel
Information exchange on digital satellite systems other than Sky
Old 12-05-2003   #1
Mod and septic resident
Channel Hopper's Avatar
I thought one of the cats was lying on the remote control for a week but now realise there is a problem with the 5400 on long term borrow
Once the unit has warmed up (after a day or so) the receiver will either change to channel 252, or when putting into standby will for no reason, switch back on. It only happens once in an evening and can be solved by pressing recall, but can be a pain when Ive gone out and expect to watch a recording later on.
I havent deleted the channel list yet as Ive got a number of SCPC feed satellites in the memeory.
Is it firmware (upgraded to TOC 2.something or other a month ago) or a hardware fault in the box ?
Channel Hopper is online now   Reply With Quote
Old 12-05-2003   #2
Billyreh's Avatar
Dude, I had this problem with mine aswell there isnt a problem with the humax you have somehow setup a chanel to keep coming up be recodered if you know what I mean.
It like a timed program option on the Humax it took me 2 weeks to find the option to remove it. What happens is if you were watching say a prog on chanel 1. what would happen the humax would jump to chanel 2.
If you put it in to stanby then it would jump out of stanby and go to chanel 2.
I will look tonite and see if i can find the rechid thing...
Regards
Billy
pc::
Billyreh is offline   Reply With Quote
Old 12-05-2003   #3
Ill buy you a beer if youre coming to Mediacast
Sounds like the logical answer and looking at the menus I could not see a video timer mechanism at all but then Ive used it when somewhat inebriated
Then theres the wife who started using it about the time this beagan happening (but thats another story)
Old 12-05-2003   #4
Billyreh's Avatar
Thats what its called somthing to do with reserved chanel or like that its not a video timer but it will bring the right chanel up when you are recording somthing.
I will look tonite if you have sorted the prob..
Billy
pc::
Old 12-05-2003   #5
Looked through ALL the menus but cannot see anything that might cause it
Your mission Billyreh, should you choose to accept it
Old 13-05-2003   #6
Finally deleted the offending channel from the list and so far its behaving OK
Must have some ident tagged onto the channel
Old 13-05-2003   #7
Billyreh's Avatar
So big guy all is good shall i still persue the mission or shall I wait for further instructions, This message will self destruct in 10 seconds...
Billy
pc::
Old 13-05-2003   #8
Dont break your neck, but if the info springs to mind (did anyone write a manual for the Toc firmware ?) it would be appreciated
Thanks again
Old 13-05-2003   #9
Billyreh's Avatar
Yeah me, program a 6-1 file and flick through the channels.
Dont think so...
pc::
5400, channel, humax, reverting
[IMG] code is Off
Similar Threads
The forthcoming channel list for Sky Analoguesat Sky Digital (BSkyB) and Astra 28.2 East General 6 03-03-2007 09:48 PM
Transponder update 30/10/03 Satdude Transponders & channels 0 30-10-2003 10:02 PM
Transponder update 20/10/03 Satdude Transponders & channels 0 20-10-2003 04:52 PM
Transponder update 20/09/03 Satdude Transponders & channels 0 20-09-2003 09:26 PM
Transponder update 21/08/03 Satdude Transponders & channels 0 21-08-2003 06:25 PM
