poor sound on all channelsInformation exchange on digital satellite systems other than Sky | |
| Regular Member Join Date: 26-09-2004
hi Area Newcastle upon tyne using zone2 60 cm mini dish universal lnb pointing at Hotbird 13 east Just bought a humax vaci 5300 an altho i have perfect pictures all the sound on all my channels are muffled beyond bearable comford listening ,including all radio stations Ive been thro 7 scart leads an all settings in the box an theres nothing to resolve this Thinking it was 2 broken scart outputs on my box tryed tuning to TV via RF lead an same result muffled sound when i say muffled the best channels are just understandable other channels just produce a very loud poppin cracking noises Sounds like a radio station on your hifi off tune abit anyone got any ideas :O( | ||
| | #5 | ||
| im hoping to have better luck the technomate my payment is pending in Ebay reason im buyin 2 receivers is 1 set up is for a family member So 1 is orderd other arrived an im having this trouble with it Si i cant put me technomate on the dish I have as explaned put my humax on a pals dish set up an same muffled sound was busy looking at how to do a factory reset but humax site said no reset for that model looking bleek then you agree a fault with box ? | ||
| | #6 | ||
| no replys i guess its offical then i bought a shite broken box ,,oh well it is my first salellite box ive had to mess on with really err well amstrad 48 channel astra analogue was me first to play with but this me first multi sat box i just bought it can only be discribed as listening to life with a perferated ear drum the audio defect ,,not that i have a peverated ear drum ,,im gussing it be like this anyways while i have it to learn about tuning an feed hunting i noticed the vaci5300 firmwere i have ia dated 2000 ive spend few days looking for links to OTA updates an hard lookin at links an posts to intructions an advice from the past i have tried numerious transponders from web pages past an present,,,an always same message ""no update avalible now " hotbird an astra 19.2e my mannual just says update via astra no frequency tho i dont have a null cable so opting for OTA update i know wont fix the audio problem but least giveme bit experiance farting about as they say so in short anyone know the latest freq i can tune my humax vaci 5300 to get latest OTA firmwere Reading about the last offical realese was dated 2004 thanks for time taken to read my moan an query | ||
| | #7 | ||
Blog Entries: 1 My System: Triple Dragon with HDD/USB stick, Dreambox 8000, Humax HDCI2000, Echostar AD3000ip & SR8700, Aston Simba, RSD ODM300. Swedish Microwave 1.2 Motorised dish / Invacom C120 twin LNB driven by the AD3000. 3 other fixed dishes. ![]() Fighting the evil 3 Dragons under the Don Quixote banner,Sir Llew persevered where others failed | According to Satcodx, the Humax OTA download frequency is on Astra 19E 12670V SR22000 FEC 5/6 Don't know if it applies to your receiver though. Llew | ||
| | #9 | ||
| Guest Join Date: 29-04-2005 Location: Midlands
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | I don't have any of this stuff, but ..... "muffled", "like pierced eardrum", etc, sounds very like poor low frequency response in sound channel, maybe like using a low-pass only "telephone frequencies " filter. Which might be an actual hardware fault, but seems very unlikely. Re-loading software should not make any difference to this at all (ie, I can't see what "programmable function" would cut the high audio frequencies!). Although, you might as well try it ...... Also, it's hard to see how a scart connector would have such a bad effect (some tiny hf loss on analogue audio signals along scarts, yes, but barely noticable!). Finding the same problem via aerial is "good thinking", and maybe suggests a problem with the tv set. Can you try using another tv, maybe briefly borrow one? Anything - just a tiny portable - will show if that's it. (or, can you feed Humax sound into a separate audio system?). (or, can you get any analogue tv channels?). TV set audio an be affected by inadequately "smoothed" power from the internal switch mode supply, maybe causing "rasping and buzzing", but doesn't sound like that either ....... ps, it isn't some really daft setup option? Can u easily set everything to "default"? | ||
| | #10 | ||
| i thought it was a scart day 1 when the receiver arrived ,just went thro all the stages problem solving but looks like a box fault what i meant spiney was the sound was poor with my box hooked up via scart leads,,so i tried tuning tv into box using an RF lead an didnt resolve the sound i also used the Video an audio l/r jack plugs to hi fi an no difference an i have 2 tv's also took it to me mates dish set up an same problem persists the only settings for audio on the humax when service serching is u can set it to manual or to auto ,,mine set auto only good thing to come out of the deal was the reciver came with a red viaccess cam which seems to work an il use the guy on Ebay which reading i know il get no joy there like i say im waiting on a technomate comming an i have a working red viaccess cam an me art card works an good signal from dish , so im slowly getten there | ||
| | #11 | ||
My System: Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!). | OK, Newcastleman32, yes that does sound like a faulty Humax! | ||
| channels, poor, sound |
Similar Threads | ||||
| poor poor poor.... | UT666 | Wavey's Jokes Corner (May contain nuts) | 0 | 10-03-2005 05:48 PM |
| BBC THREE and FOUR providing 'poor value' | net1 | Daily Satellite and Broadcast industry News | 0 | 13-10-2004 06:26 PM |
| poor sound/ itv | telly2 | Sky Digital (BskyB UK) Platform Astra 28.2E: Astra 2D Fringe reception & Tech | 5 | 15-10-2003 11:44 AM |
| Poor start for Sky's music channels | net1 | Sky Digital (BSkyB) and Astra 28.2 East General | 0 | 30-04-2003 08:35 PM |
| Poor quality | buzzbomb | Sky Digital (BSkyB) and Astra 28.2 East General | 2 | 14-08-2002 08:56 PM |
