FTA box help required
Information exchange on digital satellite systems other than Sky
Old 14-12-2005   #1
I am looking for a cheap FTA box to use at a holiday home in Tenerife. At the moment, the flat has an ancient digibox but no viewing card so it is a real pain to listen to FTA radio or TV channels on 28.2 because you have to go to Other Channels and the memory keeps wiping etc.
We have no intention of paying for a murdoch subscription so I am looking for a decent, cheap FTA box to replace it. Can anyone recommend a good one at a low price?
Thanks in advance.
mulls74 is offline   Reply With Quote
Old 14-12-2005   #2
My System: echostar 808 2CI Matrix Reloaded Cam Fixed dish 13E
Everyone seems very pleased with the cheap lidl deals but you may have to wait until lidl has stock. It seems to be a bit of a seasonal item. Follow the link below to member's comments on the lidl deal
http://www.satellites.co.uk/php-bin/...highlight=lidl
eghamhigh is offline   Reply With Quote
Old 14-12-2005   #3
Ding Dang Doo
gameboy's Avatar
My System: DreamBox 7000s - Nokia Freeview - Several GameBoys - DS Lite - ZX81 - SNES - N64 - Sega Saturn Dreamcast - PlayStation - Gamecube - PSP - iPod - iPhone - XBox - PS3 - Wii - No Life!
For £99 Maplin have a full FTA satellite system...
_http://www.maplin.co.uk/module.aspx?ModuleNo=43113&doy=14m12
or the Lidl receivers pop up on Ebay often (Comag or Silvercreast) don't think they will have then again till early 2006.
Only he who does nothing, does nothing wrong.
gameboy is offline   Reply With Quote
Old 14-12-2005   #4
My System: Skymaster DCI9900 + PC/twinhan combination. 80cm dish. GBPVR with 2 DTTV cards +hauppauge Media MVP
Wizard satellite have a Fortec FTA at 50ukp - h__p://www.wizardsatellite.co.uk/
pgh13 is offline   Reply With Quote
Old 14-12-2005   #5
Thanks - very useful. Would a fortec be better than a comag sl 65? I see a few of these on Ebay for around the same price.
Old 14-12-2005   #6
Ding Dang Doo
gameboy's Avatar
Sure the Comag can be 'patched' not sure if the Fortec can.
Do a search here for 'Comag' and you will get a lot more information ;-)
Old 14-12-2005   #7
hello,from tenerife.
i would go for a technomate 1000d for about 75 pounds.
have bought quite a few of these for friends and family.
easy to patch.you can pick up loads of channels with
with a 60 cm dish.
i
jacko is offline   Reply With Quote
Old 14-12-2005   #8
My System: DM7020 Screambox MAC OSX & windowzz 98SE Gemini 1664 on tap
If you just want a cheap digital box pop along to your local DIY store. They're about 50 euros here in france and you can get all the BBCs and ITVs and the radio in digital.
No CI Cams etc just a basic simple box. Take a look at Kelkoo.es and enter FTA or numerique or what ever it is in spanish.
whatsthis is offline   Reply With Quote
Old 15-12-2005   #9
Slightly biased Technomate Seller
go for the best...technomate tm-1000d super
it's the only receiver out of the ones everyone has said which has hardware blind search which is very fast....has regular patch....very easy to use menus etc....just read my review in the reviews section
the_wizzz is offline   Reply With Quote
box, fta, required
[IMG] code is Off
Similar Threads
Help required Claw DISH SETUP: Single sat, Multi-Sat & Motorised systems 24 15-07-2005 03:07 PM
Help required Happydude DISH SETUP: Single sat, Multi-Sat & Motorised systems 18 17-05-2005 09:45 PM
Information required Wattoo Keys and Key editing 0 30-01-2005 04:42 AM
Help required englishman64 Digital systems 6 09-09-2004 03:35 PM
Help Required........plz zafarjoia Keys and Key editing 0 12-07-2004 10:09 PM
