Manhattan Plaza ST100 questionsInformation exchange on digital satellite systems other than Sky | |
| Satellite Jumper Join Date: 14-08-2005 Location: Essex, UK
My System: Analogue FTA - Maspro ST9, Sky Digibox - Amstrad DRX100(no subscription), Digital FTA - Manhattan Plaza ST100 with motorised 98CM dish. |
hi, just a few questions regarding my Plaza ST100, Today, finally got a hole drilled through the old window frame so the wire is not longer going through the window (having to be unplugged every time when turned off) so my system can now stay on. As it is now permanant i would like to sort out a little problem i have had since i got it. Basicly the rf out to the tv is giving me a poor picture, the picture has lines going accross the screen at an angle. Also when watching a standard analogue terrestrial channel the picture is snowy, not terribly but its noticable even from a distance .As some of you may remember last year i was given my system from a very nice man who went by the name of RedAltoGL on these boards. The receiver isnt that old and still had the plastic over the display and remote when i got it so i dont think the receiver is at fault, unless someone has an idea as to what it might be. Also, i would like to set up my sky box aswell, as the Plaza has a loopthrough will it be ok to connect the digibox to this? The Markings on the back of the Plaza state 600mAmps max and the digibox states 350mAmps or somthing like that so thats not a problem, i just want to check so i dont bugger up my setup .thanks for any help and advice, i'll get there in the end | ||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | With regard to the lines across the picture, if you remove the aerial input from the manhattan, do the lines go away? If they do, then you simply need to adjust the rf output channel to a clear one. You grainy picture of the terrestrial channel is indicative of a weak signal, could be that you have it split somewhere and it needs an amp, or perhaps the connections are bad. | ||
| | #3 | |||
I suppose the lead i am using between the receiver to the tv could be knackered, would the signals/power etc going down the lead to the motor/dish be a possibility? If so i will use a length of screened satellite grade cable to see if that helps (actually i can try that tomorrow). Bit of a mystery ![]() thanks once again | |||
Blog Entries: 5 My System: Pace Sky HD, DM7000s, CubeRevo 3000HDPVR, Transparent 80cm Dish, Moteck SG2100 DiseqC motor, lots of legacy gear. Meters: Satlook Digital NIT, Televes H45 Digital Spectrum analyser. | Sounds like the connector cable then, make up a new one and the problem will probably go away. You satellite receiver would be better connected by scart anyway. You may have problems if you use the loopthrough for the digibox, as even when in standby, it still powers the LNB. | ||
| | #5 | |||
.Will leave the digibox out of the equation for now, better to be safe than sorry .thanks ![]() edit: the interference looks somthing like this, although its only when looping through the receiver:_http://www.selfhelpandmore.com/interference/tv/tv_08_0004.jpg | |||
| | #6 | ||
My System: Analogue FTA - Maspro ST9, Sky Digibox - Amstrad DRX100(no subscription), Digital FTA - Manhattan Plaza ST100 with motorised 98CM dish. | no luck Tried the same setup with my digibox and the picture was fine, the mystery deepens | ||
| | #7 | |||
| Administrator Join Date: 01-01-2000 Location: Greater London
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. |
| | #8 | ||
My System: Analogue FTA - Maspro ST9, Sky Digibox - Amstrad DRX100(no subscription), Digital FTA - Manhattan Plaza ST100 with motorised 98CM dish. | Thanks for letting me know, to be honest i wouldnt need the digibox in the same room as the Manhattan, an i have plans to have it in the bedroom to get a few extras. Looks like its somthing to do with the Manhattan itself thats causing the picture problems, i tried it on another tv and it was the same although when initially turned on at the wall there was very little interferance. It was only once it was turned on that lines appeared all over the screen and turning it off made no differance .I have a few theorys: 1. I read that there were issues with the quality of the images produced, as i am only on version 70 and the latest version was 74 i have missed the update to correct this, or rather i cant find the update on hotbird so will try the smaller dish i tried last time (which worked) On satellite superstore's site the say the following: New 72 software coming soon The issue of the video performance has been dealt with and using special video overlay software, the picture quality has been greatly improved. The hardware was not the problem, it was the software driving the video chip which at first looked like it couldn’t be over-written. A clever bit of overlay software solved that problem. Indeed they say it is at least as good as the picture quality from a good modern Sky Digibox. And, New 74 software now out Enhancements in v72 software, Channel browser sort by Alphabetical order is corrected. RGB and Composite video levels have been optimised with picture sharpness improved. Satellite name now displays in advance search download page. So its most likely that its just the software thats at fault, and i have missed the update to correct this (if i am reading it right). As i have never really had to use the rf loopthrough before (never been left set-up for a great deal of time) so never took much notice.Now i check the Plaza site daily in case an update is released, is the last update likely to still be being broadcast? Or do they only broadcast the update for a few weeks? thanks | ||
| | #9 | ||
My System: Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2. | 72 was OTA and that may be the last OTA. 74 is by PC only I believe. Rumour has it that all future updates will be by PC only and the OTA service closed. | ||
| | #10 | |||
thanks once again ![]() Edit: would this be suitable? amazon.co.uk/exec/obidos/ASIN/B000747OE4/qid=1140369472/sr=8-4/ref=sr_8_xs_ap_i4_xgl/203-3305546-1246321" target="_blank">http://www.,amazon.co.uk/exec/obidos/...305546-1246321 thanks | |||
| | #12 | ||
| all dead, just not fallen Join Date: 23-10-2005 Location: Glasgow
My System: Manhattan Plaza ST 100 Pace MSS 1000 Orbital 80cm Dish BT SVS 200 28" Toshiba Wide CRT TV Tiscali Broadband 2mb HP Pavillion PC 256mb Celeron d 2.53Ghz | that cable is the one i have, and have used it sucessfully to patch my manhattan plaza st100, by the way u may be interested to hear that a patch has been released to unlock digital+ and the likes for the plaza. | ||
| | #13 | |||
| manhattan, plaza, questions, st100 |
Similar Threads | ||||
| plaza 3300 or Fortec star 5100 | samsat | Receiver software, international Section | 2 | 13-11-2007 11:10 PM |
| Manhattan Plaza St-550 PVR | ntrip | Digital systems | 0 | 13-10-2005 01:29 AM |
| Manhattan Plaza 3300 | umarbabo | Matrix Reloaded, Revolutions and CAS interface | 1 | 18-08-2005 12:25 PM |
| Questions for the Cam experts | Samba65 | Cams and decoders General | 14 | 13-05-2004 03:00 PM |
| 1.1m, manhattan 3000 + cam. Is it OK??? | satel | DISH SETUP: Single sat, Multi-Sat & Motorised systems | 3 | 05-08-2003 08:37 PM |
